Not a lot happening with the 205 at the moment so thought I'd put up a project thread for my other car.
I always wanted an 200SX S13 but somehow ended up buying this! It had been sat for a couple of years and is on a reasonable 94,000 miles. It's the first petrol turbo and RWD I've owned as I've always fancied having a go at "getting back end out". I'll probably have either this or the 205 off the road at one time so one will always have the opportunity to be fixed and worked on.
Currently trying to get it through the MOT so have been doing various bits and bobs but its all slowly coming together!
MOT Advisories [b]June 2013[/b]:
- Rear track rod bushes worn - No imediate action required
- Rear anti roll bar bushes worn - No imediate action required
- Rear subframe bushes worn - No imediate action required
[b]Current spec list (12/10/2015):[/b]
Exhaust/Turbo
- T28 & Standard Manifold (103k September 2015)
- Custom braided turbo oil lines
- Custom braided turbo water lines
- Forge Actuator
- DemonTweeks Zinc Manifold Nuts (103k July 2015)
- Conceptua MLS exahust manifold gasket (103k July 2015)
- Lambda sensor (103k July 2015)
- 3" Japspeed stainless elbow (103k July 2015)
- 2.5" Stainless flexi downpipe
- 3" Downpipe back exhaust to 4.5" tip
Engine
- Replacement engine (103k July 2015)
- H-Dev Stage 1A S14A Chip 270-290 bhp (103k August 2015)
- Toyota 10w40 Oil (103k July 2015)
- K&N Performance oil filter (103k July 2015)
- NGK BKR7E 0.8 gap copper spark plugsla(103k July 2015)
- Exedy organic clutch, friction & thrust bearing (103k July 2015)
- Apexi air filter
- Japspeed FMIC kit (104k October 2015)
- MBC set @ 14 PSI
- Aluminium twin core radiator
- Silicone radiator hoses
Fuelling
- Walbro 255 LPH fuel pump
- SARD adjustable fuel regulator
- Audi TT 3.2 fuel filter (103k July 2015)
Interior
- Rear boot & rear seats stripped to shell
- Driftworks spin turn hand brake button
- HKB steering boss
- 350mm Deep OMP suede steering wheel
Electronics & Fittings
- 60mm 2 Bar DEFI boost gauge on manual gauge light switch
- Kenwood headunit with aux connection
- 12v Volt gauge + USB charger
- Battery isolator/cut-off switch
- Battery relocated to boot with 300A Inline Circuit Breaker
Chassis & Body
- Skyline R33 4.1 Welded diff
- Skyline R33 5x1 drift shafts
- Adjustable tension rods
- Aftermarket washer bag
- Subframe solid locking collars
- Apex/Hardrace engine mounts (103k July 2015)
- Apex/Hardrace gearbox mount (103k July 2015)
- Genuine Nissanlainconel Diff Bolts/Nuts (103k August 2015)
- Modified knuckles, by Sam Mocock (103k September 2015)
- Lengthened (30mm) and reinforced arms, by Sam Mocock (103k September 2015)
- Japspeed super lock castor/tension arms (103k September 2015)
- Japspeed adjustable steering rod arms with built in 5mm spacer (103k September 2015)
- Driftworks offset rack spacers (103k September 2015)
- Poly Superpro ARB drop links (103k September 2015)
- Front strut brace (103k September 2015)
- S14A Red side skirts (103k October 2015)
- TEIN Super Street coil overs (103k October 2015)
- Rear adjustable camber arms (104k October 2015)
- Sparco Tow Strap (104k October 2015)
- 4 Wheel Alignment (104k October 2015)
Brakes
- Z32 Aluminium front brakes (July 2014)
- Grooved disks all round (June 2014)
- Red stuff brake pads on front (June 2014)
- Driftworks front & rear braided brake lines
- Knuckle Duster hydraulic handbrake (fitted Dec 2014, replaced 103k September 2015)
- Driftworks black flexi hydraulic handbrake lines (Dec 2014)
- ABS Unit/Lines Delete (103k July 2015)
- Copper front brake lines (103k July 2015)
- Mintex rear pads (103k July 2015)
Wheels & Tyres
- XXR 527's 17x8.25 Front + Alloy Tuner Nuts (103k September 2015)
- Standard S14 16" Rear
- Extended M12x1.5 studs
- 25mm Spacers all round
- 10 x Standard S14 16" alloys re-sprayed black
Spares
- 2.5" Modified Mongoose system (straight through to back box including de-cat)
- 2 x BK 993's ET42, 8Jx18" (225/40/18 - 245/40/18)
- 4 x Rota Grid 17x7"
- 50mm rear over fenders
- Aftermarket side skirts
-laAftermarket front bumper
- Stainless T3 top mount manifold
- Stainless bottom mount manifold
- Alloy locking wheel nuts
- ToyoSport coil overs (removed 103k October 2015)
And finally some pictures I've taken along the way (please excuse lack of quality)!
1) Picking it up
2) Giving it a wash
3) Fitting an apexi filter
4) Washing/cleaning arches
5) Applying underseal
6) Preparing replacement calipers
7) Fitting replacement calipers and painting alloys black
Thanks for looking!
Exhaust/Turbo
- Forge Actuator
Engine
- Apexi air filter
- MBC set @ 14 PSI
Fuelling
Interior
- HKB steering boss
Chassis & Body
Brakes
Wheels & Tyres
Spares
1) Picking it up
2) Giving it a wash
Thanks for looking!
