10-07-2013, 12:07 PM
Wiring up a boost gauge, what wires have you used?
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg)
Ignition live
10-07-2013, 12:55 PM
Taken mine off the fag lighter and switched the fuse over so its ignition live.
10-07-2013, 02:05 PM
Oh really? Would using a live from the CD player work?
Electrics really are not my strong oiint ![]() TEAM CONROD SHITTING RALLYE!
10-07-2013, 03:17 PM
on the 205 - the cigarette is a constant live.
get a multimeter and test some on the hazard switch
10-07-2013, 03:20 PM
I have no multimeter on me at the moment, the headlight adjust switch has a constant live or ignition live?
Actually doesn't that panel only power up with the headlights? ![]() TEAM CONROD SHITTING RALLYE!
10-07-2013, 03:23 PM
it's going to be hard to find it.
If i said to you find the green wire on the hazard switch, again, a tough thing to find. You'll be shooting in the dark. What you up to tomorrow?
10-07-2013, 03:29 PM
Unfortunately working all day
there is a green wire on the hazard switch?
10-07-2013, 03:33 PM
Exactly.
It's hard without testing them ![]() I done mine yesterday on the 205, a couldn't tell you which colour it was
10-07-2013, 04:19 PM
Bollicks. @cully or Niall, got a wiring diagram?
10-07-2013, 04:44 PM
Took mine from the orange wire on the rheostat, that way it dims if you dim your dash lights. I also added a resistor in line to dim it a bit, matches in much better like that IMO.
10-07-2013, 04:47 PM
if you have a wire long enough, go from the dash lights dimmer switch, thats what I always do so you can dim the gauge with the rest of ya dash
10-07-2013, 04:59 PM
(10-07-2013, 04:44 PM)Jonny81191 Wrote: Took mine from the orange wire on the rheostat, that way it dims if you dim your dash lights. I also added a resistor in line to dim it a bit, matches in much better like that IMO. (10-07-2013, 04:47 PM)Piggy Wrote: if you have a wire long enough, go from the dash lights dimmer switch, thats what I always do so you can dim the gauge with the rest of ya dash Isn't that what I just suggested? Welding and fabrication projects undertaken, contact me for more information.
10-07-2013, 06:09 PM
(10-07-2013, 04:48 PM)cully Wrote:(10-07-2013, 04:19 PM)Matt Wrote: Bollicks. @cully or Niall, got a wiring diagram? (10-07-2013, 04:48 PM)cully Wrote:(10-07-2013, 04:19 PM)Matt Wrote: Bollicks. @cully or Niall, got a wiring diagram? There is a thread? I even searched.... ![]() TEAM CONROD SHITTING RALLYE!
10-07-2013, 06:46 PM
(10-07-2013, 04:59 PM)Jonny81191 Wrote:(10-07-2013, 04:44 PM)Jonny81191 Wrote: Took mine from the orange wire on the rheostat, that way it dims if you dim your dash lights. I also added a resistor in line to dim it a bit, matches in much better like that IMO. tiz. we agree. I started my post, then came back to it...overlap. dumbasses thinking alike Wishes for more power...
10-07-2013, 06:57 PM
(10-07-2013, 06:46 PM)Piggy Wrote:(10-07-2013, 04:59 PM)Jonny81191 Wrote:(10-07-2013, 04:44 PM)Jonny81191 Wrote: Took mine from the orange wire on the rheostat, that way it dims if you dim your dash lights. I also added a resistor in line to dim it a bit, matches in much better like that IMO. Fair enough
![]() red = 12v ign green/yellow = 0v ground
10-07-2013, 10:29 PM
(10-07-2013, 07:04 PM)cully Wrote: ^ is that the dash dimmer or headlight adjuster
NO SMOKE NO POKE
11-07-2013, 05:12 AM
11-07-2013, 06:09 AM
I took my ground from that plug but live from the dimmer
11-07-2013, 09:48 AM
Bloke previous to me had spliced straight into the ignition live and then wrapped bare wire around the clutch pedal for the ground. Don't do this. I was very f*cked off to discover it and it took ages to unravel!
04-09-2013, 10:31 AM
04-09-2013, 10:35 AM
(04-09-2013, 10:31 AM)xiaomianmian Wrote: if you have a wire long enough, go Fifa 13 Community from the dash lights dimmer switch, thats what I always do so you can dim the gauge with the rest of ya dash I always wire my things through football
![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI |
| Radio ignition live | Dean | 3 | 1,753 |
27-11-2013, 05:54 PM Last Post: DTurboTom |
