Headgasket help/ Engine rebuilding Q's/Bad to f*cking worse.
My impact bits havent let me down yet, so if gun wont move them breaker bar should, Ive taken the head off hundreds of xuds in my life, and never had a problem, so cant see it being that bad, does seem odd how your breaking to many bits though!
[Image: sigi-2.png]
So tom's not already using a breaker bar on these ?? Doh
I think what darren saying is that there should be no reason why a breaker bar wouldn't slacken them off. Tom's been using one but destroying bits...
Got some more help and we have made 7 move then broke another bit! Me pulling the bar and mate smashing them round with a hammer and chisel, just going to get another bit and should hopefully have the head off today!
From bad to f*cking worse, finally got all the bolts out thought yes here we go... head wouldnt come off, turns out you have to take the top bolt out the tensioner so i need a new one of those lol. Got the head off and theres a chunk gouged out next to the valve seat where i stupidly got a crow bar under there to lever the head off and ALL the precupts have atleast 2 cracks in, one has 4 or 5 :/ On the verge of just breaking it now and getting something else, if its this f*cked after just a few months on a td04 its not going to last another year and let me push it harder :/
Anyway pics of shit.
[Image: IMGP2539_zps34ff5f1e.jpg]
[Image: IMGP2536_zps749c53b8.jpg]
[Image: IMGP2537_zps38061edb.jpg]
[Image: IMGP2538_zps33555b4e.jpg]
[Image: IMGP2535_zps10e25a85.jpg]
[Image: IMGP2533_zps48b62bad.jpg]
[Image: IMGP2534_zpsb9683d27.jpg]
TOM :O WTF!!
The cracks in the precups is nothing to worry about, all IDI crack them, wouldnt matter at all, however the damage you did to valve dosnt look good, what on earth did you have a crowbar between the deck and the head for!!
Just find a used head and change it tbh...
[Image: sigi-2.png]
It would not come out so i tried to lever it out, then found the tensioner bolt and thought fucksakes.
You sure the cracks are ok? Doesnt look healthy to me:/
(06-07-2013, 05:33 PM)darrenjlobb Wrote: Dont worry about locking it before you take it apart, just get it stripped, and then lock everything when you put it back together, as crank will turn easily then Smile
You will need to remove both manifolds, and also extract the dowell from the engine mount bracket, or if you find that hard, remove the entire engine mount bracket.
(10-07-2013, 05:57 PM)Tom Wrote: It would not come out so i tried to lever it out, then found the tensioner bolt and thought fucksakes.
D'OH. Epic fail tbh.
Lol fail, it doesnt say about the cambelt tensioner there...
Christ man! That's crazy
Is that dowell not the one that goes through the mount into the head and holds the tensioner together though?
(10-07-2013, 06:21 PM)cwspellowe Wrote: Is that dowell not the one that goes through the mount into the head and holds the tensioner together though?
Dont think so, i think the bolt that releases the tensioner so it can take up slack goes into the head, so when i got that off the head just fell off the block. The dowel just goes through the mount and into the block.
Ah. Whatever it is, I struggled to lift the head on my first HG change until I found something wedged in there. Still.. i didn't use a crowbar lol
If im honest i didnt think it through lol. The bores looked nice though, especially since i have been defiltered for a year :/
Dont give up with it. Just get a 2nd hand head
Hammer and chisel to take the head studs out and a crowbar to lift the head off!, that's pikey as f*ck.
110749351844 eBay that on my phone so can't link
But I had the same trouble as you bought one of them and not had a issue since
Team Doesn't own a 306
New engine on the way with a bosch going to take the head off that one get it skimmed and new gaskets and seals, bosch will be sold on to make money back. Lets hope these headstuds arent tight!
Just don't use a crowbar!
Thanks Matt! Lol atleast now i've had a practise one
Got new engine day, head off in like 20minutes, now leaving the machine shop, new head is getting skimmed pressure tested and rebuilt with new everything. Hooray.
  MLS headgasket enquiries. 205dtub 14 8,630 18-02-2015, 11:56 PM
Last Post: vinny
  Headgasket failure? AdamInNi 3 2,857 31-08-2014, 10:16 PM
Last Post: AdamInNi
  headgasket ? Teddy 6 4,303 23-04-2014, 02:57 PM
Last Post: Paul Baldwin
