Removing rear drum
Removed hub nut, circlip and washer! Been smashing the drum for an hour or so with hammers and chissels, seemed to move about 10mm on top and 5 botton barring in mind me and a m8 havr been hitting it around the whole drum.
Any ideas why the bastard isnt coming off?
Frm wht I cld undrstnd v ur txt speakz innit! (just talk normally mate is easier for people to understand you, thus you may get a little more help)
You need to slacken off the shoe adjuster nut, as the shoes are holding the drum on as it is Smile
Handbrake on?
If you've got a spare wheel you don't need knocking around, put it on and batter the life out of it. I had to do the same when I changed my rear brakes. Just gives you some more leverage to get the drum off. Wink
Sorry grant was writing it in a hurry because it was raining and I had all my tools out Wink
Handbrake fully off and released the handbrake operating lever
get a crow bar in there, or a large flat head screwdriver. it will come, they do get f*cking seized, just keep ramming it, turning, ram, turn, ram, turn.. pop. giggedy.
slacken the handbrake---un-adjust it loads so the handbrake lever allows the shoes to retract.
then a big screwdriver in either side and wiggle it off.
The bearing could be stuck on the stub axle
Smash the stub axle through the centre
[Image: av5ym8.jpg]
I agree with Wingnutz.. The way I have always done it.
Dw just sorted it! Guy who lives opposite me is a citreon mechanic, run through it with me and gave me a bearing puller Wink
  Removing broken bleen nipple/How many types of rear calipers? Iaitoo 16 8,112 31-03-2016, 02:25 PM
Last Post: pug306driver
  Rear drum / hub torque setting firemoth 4 2,738 19-09-2015, 03:06 PM
Last Post: Magenta Sunset
  rear beam removing hubs Matt 17 7,863 26-06-2015, 06:12 PM
Last Post: Piggy
