Rear drum / hub torque setting
As above, what's the torque setting for theĀ 32mm bolt that holds the rear drum / hub / bearing whatever you want to call it please
On autodata it says a 306 is 185nm but I see you got a 405? It say 275nm for a 405 for some reason its different to a 306
No it's for the wife's car which is a 306. Done to 200nm in the end. Doubt it will come off lol. Thanks though
FT..../thread Big Grin
You have staked them into the groove though haven't you?
3 white knuckles & a grunt? Big Grin
Hate Housework!
  Rear Drum Bearing Thrust Washer Problem? Toms306 23 10,809 19-06-2014, 06:44 PM
Last Post: Toms306
  Gti6 brakes on front, drum on rear MarkHam 5 3,782 13-04-2014, 10:54 PM
Last Post: Mattcheese31
  306 HDI Rear Disc Brake to Drum Brake Setup Switch MY95 18 11,722 01-01-2014, 09:34 PM
Last Post: MY95
