Gti6 idle issue
I had endless problems with my ICV, did all the cleaning and fettling known to man.
In the end i got another one and its been fine since Smile (i also had high RPM idling too)
Its a right bugger though..
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
#32
Try unplugging the TPS and see what it does. Let us know.
I had a similar problem with mine, and your situation is mirroring mine. Spent aaages cleaning ICV's and couldn't get it working for love nor money. TPS is on the bottom of the Throttle Body (the butterfly operates it)
Let us know what happens Smile
Well chaps iv put a new icv in the car today. The car is now idling correctly again thank god. But the other random cutting out issue still remains lol any more ideas?
#34
(01-07-2013, 03:59 PM)Grant Wrote: Try unplugging the TPS and see what it does. Let us know.
I'll give it a try. What can I expect to happen when I unplug this TPS?
#35
All hell to break loose!
Lol nah it should struggle to fire, could not rev past 2k and the rev limiter to kick in at about 2k also. If nothing changes when you unplug it then you could have your answer there. Smile
Hey folks thanks for all your advice over the last week or so. Iv been driving the car around for a day or so and the new icv seem to have made the car idle nicely now, however it still drops revs and cuts out from time to time when you are parking up or in traffic I'm giving some redex ago in case the fuel line is dirty or something. Got any more ideas?
#37
my 6 would randomly stick on high tickover
turned out to be the butterfly loose on the throttle shaft Wink
#38
(04-07-2013, 09:06 AM)cully Wrote: my 6 would randomly stick on high tickover
I can't remember how it's assembled, are there two fixings on the shaft? Do the heads face the manifold or the outside?
[Image: sigjpg.jpg]
Serious.
#39
the shaft is split with the butterfly in the split/ two philips screws heads face filtered side the outside/into the threaded shaft /no nuts / Wink
#40
Nice, should be able to check them without removing the whole TB then.
I've just bought a new ICV and it's still not as perfect as it should be/almost stalls every now and then, going to give that a look when I cba.
[Image: sigjpg.jpg]
Serious.
#41
These gti6 sure do love to have little niggley issues. My little 1.4 Bianca just runs perfect every time. Hard to choose between the speed and coolness of the gti or the reliabilty of Bianca lol
#42
Gti6 is worth every pissy problem it throws at you Big Grin
#43
(08-07-2013, 02:31 PM)Puggie Wrote: Gti6 is worth every pissy problem it throws at you Big Grin
This
Anyway, tbh they are a really reliable engine providing service routines are stuck to. Only common issues i can think of are ICVs and map sensors.
  Erratic idle GTi6 rocker8742 18 9,732 02-08-2016, 09:08 AM
Last Post: PocketFighter
  Idle issue. luke89 2 2,318 14-03-2015, 04:52 PM
Last Post: xudlingo
  Gti6 idling issue kentiiboii 10 6,371 11-03-2014, 11:45 PM
Last Post: kentiiboii
