Fitted new 60mm springs dosnt seem low enough
Iv fitted new springs couple of weeks ago and dosnt seem low enough to me will it drop some more over the next couple of weeks or do I need to go down the coil over route
They should settle a little but not a drastic amount
Team Doesn't own a 306
Ok I hope it lowers a little more myt just not look enough cus the rear arches are smaller the car seems to sit level so shouldn't moan to much
Get some pictures up Smile
Some springs take ages to settle and drop a large amount over time, think it all depends on the quality of springs.
Are you 100% they are -40mm?
Stage 2 XUD Sedan
There 60mm springs there a cheap set of eBay made in Germany I think AW think the make is
that maybe the issue then.
Personally I would get some decent springs then adjust the rear to suit, IMO
Give them time to settle then. I think the cheaper they are the more they settle due to cheap steel.
Stage 2 XUD Sedan
Ok people cheers will leave it a couple of weeks see how we get on then maybe get some decent springs
May be a 60mm drop on a 1.4 or something but if its a '6 they already sit lower to start with so they wouldn't have the same effect
Now only a has been!!
www.autorite-sport.co.uk
Just me that thinks that photo looks pretty spot on?
Think it's cus the rear arches are smaller it myt look lower on the back the sills look level so that will do I think
i was looking at these, what's the ride like?
I'm running a set of those springs, for the money I can't fault them. They ride well and the handling is pretty spot on tbh.
cheers Jonny, these might be just what i need Smile
Yeah there sound enough and cheap so good enough for me
  TA Coilovers vs GTi6 Shocks & 60mm Springs silverzx 10 6,633 15-07-2014, 03:59 PM
Last Post: puglove
  Anyone fitted top mounts to shocks&springs? Jaymes306 8 5,220 08-06-2014, 09:42 PM
Last Post: Grant
  60mm springs paul7278 2 1,984 18-09-2013, 12:10 PM
Last Post: puglove
