23-06-2013, 01:01 PM
I went to bleed brakes on my berlingo i just bought and its air locked pretty bad, whats the correct pattern to bleed brakes on these vans?
Bleeding Brakes
Start furthest away from the master cylinder and work you way towards the nearest.
I'm not sure if the berlingo is the same, but on the 306 it goes: N/S/R--> O/S/R--> N/S/F--> O/S/F Just double check the position of your master cylinder
![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
23-06-2013, 01:45 PM
Will be the same, does it have abs??
23-06-2013, 03:55 PM
you go diagonal on non-abs . . . .nsr-osf-osr-nsf . .
23-06-2013, 03:59 PM
ABS makes no difference.
All braking systems work in a diagonal. Wishes for more power...
23-06-2013, 04:08 PM
(23-06-2013, 03:59 PM)Piggy Wrote: ABS makes no difference. did i say different? . . . . .lol tbf all mine have been no abs . .
24-06-2013, 05:19 PM
still could not get pressure in the system, no fluid coming out, changed m/c and still the same,
my method of bleeding is using a clear tube connected to a container filled with fluid with an assistant pumping never had problems bleeding before any ideas?
24-06-2013, 05:38 PM
(23-06-2013, 03:59 PM)Piggy Wrote: ABS makes no difference. It could make the bleeding a lot easier, as if it is a PH3, or a late PH2 with EBD, you could do single person bleeding using Peugeot Planet. It uses the EBD pump to bleed the system for you. Bazinga. ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
24-06-2013, 08:27 PM
no abs
| Bleeding Brakes With Peugeot Planet | Tom85 | 3 | 3,373 |
22-06-2017, 08:08 PM Last Post: Tom85 |
| Help with brake bleeding | Iaitoo | 18 | 7,729 |
10-06-2016, 06:06 PM Last Post: Poodle |
| Bleeding abs pump. | bashbarnard | 14 | 8,571 |
24-05-2015, 06:48 PM Last Post: Toms306 |
