HDi rod big end shells
Just wondered if anyone knows the Peugeot part number for HDi rod big end shells?
You can get Glyco bearings on ebay 40 odd quid if i remember, not what you asked but every little helps ay :p
Has our service box login been fixed yet? That should tell you. PM me if you need a reg.
Ok cheers i might just give peugeot a ring. Do you know if they are all the same on HDis?
On the 306 version? Afaik yeah.
Yep cheers
Is anyone able to find out the peugeot part number for the shells?
My mate has got some new 1s and we are not sure if there the right 1s though they look the same.
[Image: shell_zps2035900a.png]
Hope that helps, I inputted my VIN for the above.
Got some shells sorted.
Just wondering if anyone knows which way the caps go on the bottom of the rods. Does the notch on the rod and cap go the same side or opposite side?
Sent ya a txt should explained it
Any chance you could share it here so other people might be able to use the info? Cheers!
Gonna get a pic of frosty
The notches go into indents on the end caps and then put them opposite
Ends so they go up on to flats on the bottom part and top of rod this makes it so they don't slip or spin its quite hard to explane with out it in me hands if you know what I mean
I will get a pic when I go down work
Appreciate it, cheers fella.
Some pics. What I want to know is do the caps go this way
[Image: null_zpseb2070ae.jpg]
Or this way
[Image: null_zps5eff9069.jpg]
second picture the shells have the same marks and when there placed oposite the shells cant spin in the caps
the outside of the rods has writing on one side across the two parts IIRC, line the writing up with itself
As cully said second pic is right
(02-06-2013, 05:35 PM)mikey b Wrote: As curly said second pic is right
Who?
Cheers for the help guys
