HDi rod big end shells - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: HDi rod big end shells (/showthread.php?tid=13427) |
HDi rod big end shells - Frosty - 01-05-2013 Just wondered if anyone knows the Peugeot part number for HDi rod big end shells? RE: HDi rod big end shells - Tom - 01-05-2013 You can get Glyco bearings on ebay 40 odd quid if i remember, not what you asked but every little helps ay :p RE: HDi rod big end shells - Poodle - 01-05-2013 Has our service box login been fixed yet? That should tell you. PM me if you need a reg. RE: HDi rod big end shells - Frosty - 01-05-2013 Ok cheers i might just give peugeot a ring. Do you know if they are all the same on HDis? RE: HDi rod big end shells - Poodle - 02-05-2013 On the 306 version? Afaik yeah. HDi rod big end shells - Frosty - 02-05-2013 Yep cheers RE: HDi rod big end shells - Frosty - 09-05-2013 Is anyone able to find out the peugeot part number for the shells? My mate has got some new 1s and we are not sure if there the right 1s though they look the same. RE: HDi rod big end shells - pugbug - 09-05-2013 ![]() Hope that helps, I inputted my VIN for the above. HDi rod big end shells - Frosty - 01-06-2013 Got some shells sorted. Just wondering if anyone knows which way the caps go on the bottom of the rods. Does the notch on the rod and cap go the same side or opposite side? RE: HDi rod big end shells - mikey b - 01-06-2013 Sent ya a txt should explained it RE: HDi rod big end shells - Poodle - 01-06-2013 Any chance you could share it here so other people might be able to use the info? Cheers! RE: HDi rod big end shells - mikey b - 01-06-2013 Gonna get a pic of frosty The notches go into indents on the end caps and then put them opposite Ends so they go up on to flats on the bottom part and top of rod this makes it so they don't slip or spin its quite hard to explane with out it in me hands if you know what I mean HDi rod big end shells - Frosty - 01-06-2013 I will get a pic when I go down work RE: HDi rod big end shells - Poodle - 01-06-2013 Appreciate it, cheers fella. HDi rod big end shells - Frosty - 02-06-2013 Some pics. What I want to know is do the caps go this way ![]() Or this way
RE: HDi rod big end shells - cully - 02-06-2013 second picture the shells have the same marks and when there placed oposite the shells cant spin in the caps RE: HDi rod big end shells - Dum-Dum - 02-06-2013 the outside of the rods has writing on one side across the two parts IIRC, line the writing up with itself RE: HDi rod big end shells - mikey b - 02-06-2013 As cully said second pic is right RE: HDi rod big end shells - cully - 02-06-2013 (02-06-2013, 05:35 PM)mikey b Wrote: As curly said second pic is right Who? HDi rod big end shells - Frosty - 02-06-2013 Cheers for the help guys |
