Miami Phase 1 XUD Project! FOR SALE £800
#61
Ste this looks fapping awesome! Look forward to seeing this when I pop up for the 205 when I've recovered Big Grin
Official Team Go-NAD fan club
#62
Haha cheers man! Yeah you will Smile
#63
Fitted the rest of the interior yesterday Smile
Before: [Image: B0B9B4AF-1623-4285-8AC0-1472A2D412BA-278...1FE6C8.jpg]
After:
[Image: 2C2E77D8-1428-497C-92B3-24BDAF87DAB4-278...737AE8.jpg]
Miss the exhaust noise echoing around the car already
#64
Have you got any c pillar and boot trim? should have said when you were over the other day as I have two sets going spare
Ah that would of been good mate! All more weight though (the boot trim) Wink
#66
Today was raising the rear beam! Was a lot harder then expected as it appears to of been done the notch method in the past and the drivers side was seized solid on both bars, we had to to take the trailing arm off and get it in a press, put ten tonne of pressure on it and also heat it up at the same time!
I think it looks loads better, raised it about 4cm
Anyway pictures:
Before:
[Image: 13DF0CB0-7DA2-4E88-9EED-2845EE906F4A-386...B233D1.jpg]
During:
[Image: 8DF962B0-E135-402B-8867-D177FDBCE13C-386...726842.jpg]
[Image: A0E24C77-4B9D-4C06-BC70-2145ED5292F2-386...95DB10.jpg]
[Image: F7A0C96A-267F-49BE-ACAB-B57641C1DAE6-386...3F213E.jpg]
[Image: 66F46B5D-D9AC-46D9-B79E-9946A01FBFE4-386...51D69C.jpg]
After:
[Image: CB3A7466-4F88-4B6D-B79F-FCC4CB440B80-386...E37269.jpg]
[Image: 213F639C-FD98-4E6F-8319-0B5A981AD3E6-386...FE5E10.jpg]
I think it looks loads better, and its a much better drive with it higher Smile
Thanks to Mitch for helping!
#67
waaaay better Smile so jealous of your access to a ramp, ive destroyed my back fitting the manifolds last night Sad
Way better mate!!!
I hate stupidetly low 6s in the back....
BTW love the color!!!!
#69
Makes such a difference to the drive as well! Smile
Blaze '6 and Blaze D-turbo!
#70
(27-05-2013, 04:22 AM)ozonehostile Wrote: waaaay better Smile so jealous of your access to a ramp, ive destroyed my back fitting the manifolds last night Sad
I have access to a garage with a pit. Works brilliant but pain in arse getting in and out all the time. Car has to be on stands as well because my uncle who built the pit and garage is a short arse
#71
Thanks guys, it's much better now! Yeah having access to that whole workshop and the lifts is brilliant, makes everything so much easier.
Was saying yesterday I would hate to try and do that on the floor!
#72
Just needs a half cage in Wink
#73
Haha noo it doesn't.
Well this happened yesterday:
[Image: B5D29C0E-106F-4277-B584-7C4A18486179-620...429C16.jpg]
Started to fix it, took the doorcard off and was undoing the bolts holding the motor in when I realised I had left my replacement motor at my dads work. So being held up with tape at the moment,
#74
Tried fixing the window today at work, got the new motor in and it goes up and down, but the window falls to one side when moving. Don't think the clip is holding it tight enough
Are there any other runners or things that keep the window level in the door other than the white flaps for the side nearest the wing mirror?
Gave it a quick wash anyway
Before: [Image: 2EC6F043-4E93-477E-988B-AAF326DD9677-953...A8FDAD.jpg]
After: [Image: DE54A369-9EB0-4E74-909D-71677EEA8592-953...2A38FD.jpg]
#75
has the peg that goes into the glass itself broken? theres a plastic peg on the runner that pushes the glass up or down and the plastic ring that it goes into often cracks and would lead to the glass moving. same things happened on the sedan
what ozone said there is like a guide bit that clips onto the glass and slots on the runner on the door pillar
#77
Thanks guys.
I think as Zakk said the plastic ring that sits in the window part is missing.
The peg is fine though. It's just not sitting tightly in the window so it is able to move easily, I will hopefully find an appropriate bung somewhere which might fix It, or il think of something.
#78
Meh not drivers side so its fine hahah
#79
True
Did a few little things today,
Cleaned it:
[Image: 9F8D4A9A-021E-4546-A94E-B67FA7E4D49D-150...48ECA4.jpg]
[Image: 5087E2B6-9A90-4749-ADFF-6F1F6A0DFFC1-150...7D1A31.jpg]
Secured the front bumper a bit better as it was loose.
Been trying to get my head round the window motor again. The one that's in at the moment is pretty slow and struggles to lift the window quickly so thinking a better replacement might be a good start.
3door and 5door window motors are different yes?
Changed the boost gauge piping as it was only reading 9psi. And location because I only had a short piece of pipe:
[Image: 79030399-DF84-4B12-ADBC-FA028220A64D-150...28E367.jpg]
It's still only reading 9psi which is odd as it goes really well, that's two different bits of piping and two different gauges now. Any ideas?
Thanks!
#80
Is it kinked anywhere or got a split? Checked all boost piping from turbo to inlet?
#81
Worst thing about black wheels... Really need to keep ontop of the tyre gel otherwise it starts to look a bit shite! And yes 3 and 5 door motors are different!
(03-06-2013, 10:25 PM)the milkman Wrote: Is it kinked anywhere or got a split? Checked all boost piping from turbo to inlet?
No pipe isnt kinked or spilt
It doesnt feel like it had a boost leak to drive it though, it pulls really well
Feels much quicker than my old one which was bosch t2 on 18psi and this one is still on lucas, hmmm
(03-06-2013, 11:07 PM)Tom Wrote: Worst thing about black wheels... Really need to keep ontop of the tyre gel otherwise it starts to look a bit shite! And yes 3 and 5 door motors are different!
how do you mean about the wheels?
I thought so, thanks!
#83
Hmmmm sticking gauge? Take it out and put it in someone elses that's boosting atleast then you can rule that out? I had a sticking gauge in my ph1 that wouldn't go over 6psi!
#84
I've tried two gauges, and the one was in the 205 and my other 306 and was fine
#85
Has it only just gone down to 9psi or since you relocated?
#86
Been 9psi the whole time
#87
I mean you need to keep your tyres looking black otherwise they start to look bad because the the wheels are properly black but the tyres can fade :p
Oh right yeah! I do have some autoglym tyre stuff. So will have to whack it out soon
#89
Tyre gel? ste wouldnt now where to start with that Wink i have found that clip for you breadbin, i have a bung thing somewhere too, it does got strangely well for 9psi, and its on lucas too
#90
Awesome cheers bro Smile
  Project T Phase 2.5 Diablo DTurbo... Kwik 90 80,735 24-02-2021, 11:51 PM
Last Post: stevieg
  Cherry Red Phase 3 HDI Project daniel909 24 18,111 12-02-2017, 11:21 PM
Last Post: daniel909
  Phase 1 project Adam CD P1 27 18,110 18-06-2016, 12:49 AM
Last Post: Adam CD P1
