100w Bulbs
Will the head light loom handle 100W bulbs in morette lights? i know there not legal but id say there safer than Hid's
Likelyhood is that they will handle it fine, It "could" cause shortings and Blow fuses, I ran them in mine for a couple of weeks but then they both blew so just put some 55w in, and could hardly notice the difference in light output.
On the 306 waiting list.
just want to give them a try, but dont want to burn my loom out, morettes are crap on dip, worse than holding a lighter out the window
Just get some decent bulbs osram night breakers are good
[Image: SDC10442-1.jpg]
probably burnout the stalk switch
Do you think i can make h7 bulbs fit in h2 lights?
I had some 100w bulbs in my roof spot lights and they burnt them selves out..went dim and black..stuck some 55w in there and really happy with them..I think as the 100w arnt road legal they arnt to the same standard maybe? Either that or was just cheap bulbs i had but wouldn't bother again
av got 100w headlight bulbs inmy ph3 headlight and there fine Smile
[Image: mintsig.jpg]
STAGE2 XUD DEAD ATM ENGINE REBUILD
GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
COMING SOON TD04 Big Grin
100w bulbs burnt my relay out . . . . . .don't bother is my experience . .Smile
I had 100w bulbs worked great but when i up'd them to 120w they burnt the wires out. This was the standard car wiring also
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
