100w Bulbs - Printable Version
+--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23)
+--- Thread: 100w Bulbs (/showthread.php?tid=1345)
100w Bulbs - Daniel306 - 06-02-2012
Will the head light loom handle 100W bulbs in morette lights? i know there not legal but id say there safer than Hid's
Re: 100w Bulbs - Jake - 06-02-2012
Likelyhood is that they will handle it fine, It "could" cause shortings and Blow fuses, I ran them in mine for a couple of weeks but then they both blew so just put some 55w in, and could hardly notice the difference in light output.
Re: 100w Bulbs - Daniel306 - 06-02-2012
just want to give them a try, but dont want to burn my loom out, morettes are crap on dip, worse than holding a lighter out the window
100w Bulbs - Jonny b - 06-02-2012
Just get some decent bulbs osram night breakers are good
Re: 100w Bulbs - cully - 06-02-2012
probably burnout the stalk switch
Do you think i can make h7 bulbs fit in h2 lights?
Re: 100w Bulbs - wil_Dtub - 06-02-2012
I had some 100w bulbs in my roof spot lights and they burnt them selves out..went dim and black..stuck some 55w in there and really happy with them..I think as the 100w arnt road legal they arnt to the same standard maybe? Either that or was just cheap bulbs i had but wouldn't bother again
Re: 100w Bulbs - studturbo - 07-02-2012
av got 100w headlight bulbs inmy ph3 headlight and there fine Smile
Re: 100w Bulbs - Mattcheese31 - 07-02-2012
100w bulbs burnt my relay out . . . . . .don't bother is my experience . .Smile
Re: 100w Bulbs - HDIkyle - 07-02-2012
I had 100w bulbs worked great but when i up'd them to 120w they burnt the wires out. This was the standard car wiring also
