15-05-2013, 09:29 PM
![[Image: IMG_1468.jpg]](http://s21.postimg.org/chpcrcu5z/IMG_1468.jpg)
What do you think. Leaky injector or leak off gone?
its like this on 1 and 3 .
Injector or Leak off?
![]() What do you think. Leaky injector or leak off gone? its like this on 1 and 3 .
15-05-2013, 09:53 PM
Looks like the leakoff to me as its all round the top. Plus its a cheap easy fix which you might as well do first
16-05-2013, 07:58 AM
Does anyone know the diameter of the nipple. Went to Halfords yesterday and they had 4.3mm 7mm and 9mm didn't know what to choice. If I pull one off whilst the car is off will diesel piss out?
16-05-2013, 07:59 AM
You will get a little bit buy only what's in the pipes it won't piss out, they do a kit in Halfords perfect for the job
16-05-2013, 08:42 AM
Do you know what diameter they are?
16-05-2013, 09:27 AM
Make sure the kit comes with proper solid blanking plugs like this:
Some kits come with a little plug you shove/glue in the end of the pipe - this will come flying out sooner or later and you'll piss diesel everywhere!! Trust me I know, luckily for me I was only at the shops - used near a quarter of a tank to get the mile or so home tho!
16-05-2013, 03:20 PM
I got the kit from kit from halfords , the 4.3mm version and yes it has them in there. Do I put it on the last pipe only?
16-05-2013, 05:19 PM
You can put it where ever you want, although that would complicate things.
Put it on either the first one or the last one and make sure all the injectors are connected to eachother and the fuel return on the pump There is also a guide in the guides section.
| Injector leak | doogle-d turbo | 8 | 4,048 |
07-09-2014, 11:48 AM Last Post: rikky |
| Injector leak off hose | devils_fuel | 33 | 14,485 |
28-03-2014, 10:18 PM Last Post: devils_fuel |
| injector leak?? | Piggy | 11 | 6,808 |
10-12-2013, 04:37 PM Last Post: Piggy |
