Help, broke down!
#61
The cable goes down and there is a second plug lower down on the block that you could take the readings off. It's yellow and might be cable tied together.
#62
Brilliant mate, muxh easier!
Right when I hook up to the yellow plug that comes from the fprs I got nothing at all. When I connect to tje yellow plug that im assuming comes from the fpr I get 8.6 on the glow plug posistion and 7.6 when cranking.
#63
That's not right, what are you measuring in?
You should be getting at least something from the pressure sensor, if there's nothing showing i'd be having a good look at that.
That mate.
There's 3 wires from it isn't there, a green pink and white. Does the pink and white go to the fpr and the green a live or something?
#65
Not 100% tbh, one is power, one's an earth and the other is to the ecu i think.
Did you manage to sort out an autodata account? That'd tell you which is which.
Havent been to to compuer mate but will sort that out tonight.
If there is nothing plugged into the sensor then it wont be powered will it so I wont get a reading? I dno!
#67
Erm, no. Why would you unplug it?
So I can put the multimeter in to it to get the reading. Got autodata on anyway but not sure what to look for.
#69
Defiantly something up with the injectors as they measure 0 ohms and as it shows here in autodata they should measure 0.2ohms.
#70
Yeah stick your mm needle into the wires.
Dont have mm needle lol will sort it tho and get back with a reading.
Something has shortened all the injectors tho don't you think?
#72
http://s1080.photobucket.com/user/Jonny_...t=3&page=1
This might help. Password is the same as the album title, but all lower case with no spaces
#73
Cheers for that mate will have a good look through them.
Where abouts in autodata is all that as I have it on the pc.
#74
It's not..
I "acquired" it through a guy I know who's an RAC patrol.
#75
I've never heard of the injectors being "shorted out" and i'm not even sure it's possible. Plus you'd struggle to do it with the voltage generally found around a car, especially considering it takes 80v to fire them compared to the 12v everything else uses lol.
Two minutes on google and i found this for you: http://www.obd-codes.com/p0200
I still think those codes are a red herring myself, can't understand how braking hard would have affected the injectors at all.
Any luck finding someone/some program that can sort you some live data?
(13-05-2013, 06:11 AM)Poodle Wrote: I've never heard of the injectors being "shorted out" and i'm not even sure it's possible. Plus you'd struggle to do it with the voltage generally found around a car, especially considering it takes 80v to fire them compared to the 12v everything else uses lol.
Brilliant read mate, will try all that when im home later. Wouldn't I of got that code tho when I read them if this was it? I dno, its strange I have no codes now I have cleared them
I know what your saying about not being able to but its just they defiantly measure 0 ohms which they shouldn't according to autodata.
Yeh, I have someone coming at the weekend with a pp2k but would like it sorted before then lol I have autodata now but I guess it can only help so much!
#77
Yes, I would expect the codes still to be present if the injectors were genuinely at fault. Still reckon its likely to be a connection or loom issue somewhere myself.
Well I will check all wires and loom later. So it should see 80v when cranking?
Forgot to put this yesterday. This what I got when I measured the injector connectors
http://s1018.photobucket.com/albums/af30...121152.mp4
#79
You should see pulses of 80v, you might find your mm isn't quick enough to record them though tbf. Will have a look at that vid later.
Ok mate and maybe. Will buy another one later to confirm.
Cheers
#81
Youll pay big money for one that can measure cr injectors pulses tbf, be better off buying pp2k imo.
Oh right.not sure then. In the video it fluctuates between different volts so I dno.
What do you think about getting someone out to diagnose it? Think they will have the appropriate software.not sure how much they would charge tho.
#83
Don't know tbh mate, depends how desperate you are to have it back on the road this week. I think most specialists charge at least £100 for a call-out, and a lot won't guarantee they'll fix the problem for you either.
Stuff that then lol
#85
Yeah, you need like a picoscope thing to measure the injector pulses lol! I doubt you'll do it with a normal multimeter as we couldn't with the college ones.
Are you anywhere near a garage? If so, I'd tow it down to ask them to have a 5 minute look for a few beer tokens to see if they find anything you missed. They'll probably stick it on a decent code reader as well. Cheaper than getting an auto-sparky out lol!
#86
Oscilloscope type thing Tom?
(13-05-2013, 05:23 PM)Tom Wrote: Oscilloscope type thing Tom?
Yeah, Picoscope is the brand name I think.
Huge piece of equipment that looks like its been nicked from the cardiac ward at the hospital....
#88
Not really near a garage.
This is what I have found
Frps 1.3v OK
Fpr at multi plug 0.3 ohms OK
Fpr at connector 11.4v OK
Crank posistion sensor 11.2ohms ???
Should be between 315-405 according to autodata.
Could it be the wiring going to it or probably the sensor?
#89
405Ohms? Is that through the sensor? That's massive resisitance, sounds like its shorting out inside the sensor if its as low as you say.
#90
Yeh it is mate
Users browsing this thread: 12 Guest(s)
