smoke from under car
Started my car up this morning and just happened to look underneath and noticed smoke coming from under the engine. It kicks out white smoke on cold start up but what's probably leaking? And am I looking at an easy/cheap fix?
2000 2.0 HDi Estate
Probably just the exhaust blowing from the down pipe you may need to tighten up the two bolts that hold it on.
Bye Bye D-Turbo
Is it connected with a solid pipe or flexible pipe? Would a decat pipe join onto the bottom of the manifold?
2000 2.0 HDi Estate
Its like a flexible flange type thing, with a conical steel gasket inside. Mine had no gasket when i took it off. Then the bolts have springs and washers on them.
if you open the bonnet and look down the back of the block can you see any smoke from there?
Yes ozone there is a little but more underneath the car.
2000 2.0 HDi Estate
If it's coming from the bay could be exhaust manifold gasket.
Bye Bye D-Turbo
Just had a look under the car properly - the exhaust is leaking from the weld just in front of the cat!
2000 2.0 HDi Estate
Bit of exhaust paste it will be fine.
Bye Bye D-Turbo
decat ordered!!!
2000 2.0 HDi Estate
  Rough startup....smoke.. lots of smoke.. toseland 8 6,908 17-06-2014, 10:35 PM
Last Post: madmadmax
