Wheel Offset Question.
Im looking at a set of wheels here that are et38, what width of spacer would I need to fit them to a 306?
Im guessing id need a 20mm spacer?
Cheers.
Depending on the width 20mm would be about right!
Should have mentioned they are 7j wide.
Should be fine with 20mm mate providing your beam is ok!
I always use this, you might find it useful.
Www.willtheyfit.com
Yea beam is ok, thats a handy website, cheers mate.
No probs mate, might be pretty close on the inside so if you can get 25mm spacers I would as they will be about 11mm closer to the inside of your arches than standard clones with 20mm spacers.
Im still not decided if i'll go for them yet, if i went for a 25mm spacer, would i have much clearance on the outer arch, im right low so i dont want it poking out that much.
Well im running 6.5j at et16 and theres bags of room on the back, the front is pretty close tho
I must check tomorrow what width and offset the wheels i have on at the minute are, cause ive only a couple of mm of gap at the rear outer arch, and the fronts rub the archs when im turning (need a smaller tyre)
7.5 ET 15 with 4mm spacer so et 9
no problem
  Quick question about cyclone wheel bolts titch 11 6,287 06-05-2014, 09:58 AM
Last Post: cully
