03-02-2012, 06:41 PM
Ha ha mine has been airborn a fair few times
Ebay Coilover Spring Swap
03-02-2012, 06:42 PM
The bearing in wrong? Whats the bearing? I didn't put them together I kinda watched so I didn't know what parts are what lol
03-02-2012, 06:51 PM
Matt Wrote:The bearing in wrong? Whats the bearing? I didn't put them together I kinda watched so I didn't know what parts are what lol I forgot that curt had fitted them earlier, I wouldn't think he would fit them wrong, the man knows his way round a 306
03-02-2012, 07:15 PM
Haha, yeah, Chris I can assure you the bearing isn't in wrong, think things would have been somewhat worse if that was the case
![]() The top mounts Matt
03-02-2012, 07:16 PM
I don't see how you could really fit it all wrong? It went together so well haha. Unless I've put extra bits on the top mounts that isn't needed?
03-02-2012, 07:24 PM
No, you can't. I can assure you it's put together right, even if it was dark when we finished haha
03-02-2012, 08:02 PM
Mine are wound all of the way down with helpers. Think I will keep my helpers in and buy some shorter stiffer springs. Dont want them to unseat when jacked up or going over a bump. I will email jamma and report back when he has the length of the original spring!
03-02-2012, 09:29 PM
After all this, and I'm just gunna leave mine alone haha. Don't want to risk f*cking it up. Going to put a splitter on too bring the bumper down lower
03-02-2012, 09:30 PM
I will try and find out the legth of the standard springs then get osme shorter ones!
04-02-2012, 10:16 AM
Jonny b Wrote:Ha ha mine has been airborn a fair few timesYep mine too. Rippthrough Wrote:It'll be on the TUV documents.Believe it or not they did come with TUV documents! the only issue with these is that there appears to be 8 pages of A4 information scaned in and reduced to fit on a single sheet of A4 Oh and theyer all in german. Just trying to work it out now. Matt Wrote:Let's get a welder out then move my top mounts lowerIdiot, you mean higher. Dan! / Curt The reason yours go -90mm and still have thread left is that 306 dampers have the issue of drop link mounts meaning that the threadded body can only be so long. Matt / Curt the top mount bearing would go in either way upbut only one way is right and itn not the way it comes out the bag from peugeot
04-02-2012, 10:22 AM
Dum-Dum Wrote:Matt Wrote:Let's get a welder out then move my top mounts lowerIdiot, you mean higher. We have already established I'm an idiot. Keep up with the time
04-02-2012, 11:06 AM
I was only reitterating that fact.
Right ive had a good look over the TUV certificate and there is no mention of spring weight apart from i keep seeing 1000kg max so is there anyone whos fluent in german who can come and have a look at it for me. I have however worked out the spring lengths and stuff Helper spring (Evo 100) Wire Guage 5.3 x 9.9mm Turns 5.5 OD 82.2mm Spring Length 109mm (4.29") Main spring (Evo 1010) Wire Guage 10.3mm Turns 8 OD 82.2mm Spring Length 171mm (6.73") Just a thought if the numbers on the springs are in kgs but should have a decimal place Evo 100 = 10.0kg = 22lb Evo 1010 = 101.0kg = 223lb Not a clue if thats what they mean but potentially not a bad guess?
04-02-2012, 12:10 PM
Damn doesn't look like we can get much shorter main springs then does it...
04-02-2012, 12:25 PM
You can get 5" ones
I have a friend who is fluent in German. But i didn't get the certificate in mine, or if I did I threw it away haha. Anyone what to scan it up and I can show her?
04-02-2012, 12:33 PM
Here you go: http://item.mobileweb.ebay.co.uk/viewit ... 0293371452
Are coilovers springs definitely 2.25" in diameter? ![]()
04-02-2012, 03:08 PM
Nah Jim i think theyer 60 or 70mm
04-02-2012, 03:11 PM
Ok 82.2mm OD - 10.3mm -10.3mm = 61.6mm ID so id say youd probably be ok with 60mm or 2.5" but probably not 2.25"
04-02-2012, 07:34 PM
Right being the legend that I am I have emailed TA Technix.
I have used the below email translated into German Quote:Good Afternoon,
04-02-2012, 09:33 PM
I'll work the spring rates out for you later when I've finished playing in the snow.
![]() If they're metric they're probably 60mm ID springs.
04-02-2012, 10:06 PM
Theyer German so i assume theyer metric.
Also the 223lb sounds about right form what i guessed at. With a bit of luck ill get new springs next month
06-02-2012, 11:14 AM
Got an email reply (at 7am this morning)
Quote:Hello Mr. Chris, Dosent entirely help on the poundage but its a start
06-02-2012, 11:26 AM
Do you have the TUV certificate chris? Could ask mr or mrs.moonstone nicely as AFAIK they are both fluent in german
06-02-2012, 11:42 AM
I need to get it scanned at a readable quality mate
Dum-Dum Wrote:I need to get it scanned at a readable quality mate Get on with it then!
| Coilover protection | lolsteve | 6 | 3,776 |
09-01-2015, 10:22 PM Last Post: lolsteve |
| gaz coilover rebuild cost | lolsteve | 9 | 5,874 |
04-11-2014, 08:52 AM Last Post: lolsteve |
| TA Technix coilover topmounts | toyo16 | 2 | 2,689 |
28-05-2014, 05:23 PM Last Post: bashbarnard |
