Whistling Noise
Hello all,
I hope someone can help. My car has developed a very high pitched whistling sound between 2/3000 revs and more so at higher speed mainly from 50 upwards!
It's only started happening in the past few days.
Thanks
Dan
Is that on light throttle or hard throttle??
has the performance changed?
is there any smoke from exhaust while this happens?
It's approx half way on the pedal travel not thrashing it.
Not that I can tell just a god awful noise.
I couldn't see any smoke, it was just getting dark and I was on the motorway.
try a hard boost run, 30-60mph in third...as the boost comes on see if the whistling comes on with it...if so...start searching for a boost leak...or new turbo...but lets hope boost leak.
it could alternatively be a aux belt...
friend of mine had me getting a new turbo for her 306....whistling noise....she was 100% on it...till the aux belt snapped
I have done the aux belt recently, but could be. I'll try do that tomorrow. Anything else to look for?
suspect belt if you done it recently...worth a quick look...see if loose
I'll take a look tomorrow. I'll try record the sound too.
Sure you've set the tension on the aux belt properly? Could be a dodgy pulley especially if it's tightened too much
I had similar was tensioner, started whistling then screaching then grinding over a fair few weeks tho
[Image: J5hxCcC.jpg]
If you did the belt without a new tensioner then the tensioner is probably failing, same happened when I done the belt on my hdi. New tensioner sorted it.
Cheers for all the replies. I'll check the belt then. I did it without a new tensioner as it was like new and felt fine, also tensioned it according to the manual.
Well today I have been out in the car and done as suggested and don't think it's my aux belt as it only happens between 2500/4200rpm and then stops again. I have attached a video sorry about the quality but it' the only way I could get the video on my own.
[Image: th_12422DEB-A8B0-41B0-A98B-53943F264F38-...1908ce.jpg]
Noise can be heard from 20 seconds onward.
Thanks
Its the compressor wheel touching on the housing, time for a new turbo
Ohhhhh damn! Better get looking then. What we taking time wise and difficulty for replacing?
Thanks to darren its easier, if its your first time book a weekend for it
Ohhh that looks ok. I think I could do that myself, just need to find a new turbo or get mine refurbished.
Remove the belt and start engine. If noise goes away, then it is coming from one of the pulleys on the accessories, thus eliminating a vacuum leak on the engine.
(23-01-2014, 06:30 AM)natashajohny Wrote: Remove the belt and start engine. If noise goes away, then it is coming from one of the pulleys on the accessories, thus eliminating a vacuum leak on the engine.
Hi mate but if you look at the date it was a few months ago he posted this lol
  Loud whistling!! underground375 11 5,633 23-07-2013, 08:58 PM
Last Post: underground375
