306 brakes on a 106
not getting any answers on 106oc...
the fact sheet on 106oc shows that 247mm vented discs and calipers (106gti etc) fit under 13" steels.
I have some really good 247mm discs and pads and calipers off the cossack I was going to fit to the 106nad...
but they dont seem to fit at all...as in they will go on but the 13" is no way going on...
any thoughts?!
i assumed the calipers would be the same?!
I know Samass has xsi brakes on his, but think that's under 14" steels
I think they only put the 247s under 14" wheels mate. I know mine were smaller than that on my 106 and the wheel was filled but that was 13" 3 stud lol
says on here that the 247 should fit under 13's unless the 247's are different between the 106/306
http://106owners.co.uk/forums/showthread...ion-Thread
Just get some 15's on it and put 283mm on there Wink you will need that extra stopping power when you xud it
the standard disc size on pov 106s is 247mm...the upgrade is the vented disc and larger caliper.
283mm is good enough to stop any upgraded gti6...
bit silly for a car 250kg+ lighter!
the 1.9 is only 15kg heavier than a 1.5
(10-04-2013, 07:56 AM)Chris_90 Wrote: says on here that the 247 should fit under 13's unless the 247's are different between the 106/306
exactly what I read
I'll sell you know at of swollowes cheap
Everyone on 205 forum raves about the standard 205 GTI 1.9 247 calipers being the business with decent pads. Might be worth a look? Fit under 14's.
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
(10-04-2013, 10:31 AM)kentiiboii Wrote: I'll sell you know at of swollowes cheap
go on....
pm me
I'm fairly sure my ph1 1.4 had 247mm brakes under the 13' steelies
Smallest brakes fitted to a 306 were 247's and lots came with 13's as standard.
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
must be these particular steels....grrrrr
Space em out
OR, I have the old 13" steels off the nad if you want, all with good tyres. I give you good price.
nah seriously, spaced out would be an understatement...I tried the 13" steels on the 306 with the 247s and they just touched, so I got some cheap 5mm spacers....
fitted it all up the 106 and I would need like 20/25mm hubcentrics!!!
could you take a pic of the 13s...so I can see if they look diff?!
Yeah sure, ill get one as soon as I can. Inside and out?
yeah, just curiosity killing me now
