Exhaust!
Exhaust!
Can you mate up a decat and a different centre pipe with the standard back box on a 1.9 D-Turbo?
The back box is the most restrictive part so you want to get that out, just get some straight pipe cut the cat out weld a bit of pipe in and take back box off and weld pipe in there to sorted the center box is'nt that restrictive
(04-04-2013, 07:07 AM)Chris_90 Wrote: The back box is the most restrictive part so you want to get that out, just get some straight pipe cut the cat out weld a bit of pipe in and take back box off and weld pipe in there to sorted the center box is'nt that restrictive
Can find a subtle exhaust backbox, want it to be straight through but have a dummy box so i dont get any fuss from the police.. hmmm might have to email powerflow or something.
Anymore suggestions on a straight through d turbo zorst?
just remove the centre box, replace that with a straight pipe...like £5 from a motor factors
then use the centre box to replace the back box...using the bits of spare pipe and some jiggery pokery.
basically for a tenner you can have a straight through that wont embarrass you or get bad attention and at same time see some gains
LOL forgot how fun owning a french car was! bodged up tot the eye balls.. will have a play and see what i can come up with!
