Exhaust! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Exhaust! (/showthread.php?tid=12499) |
Exhaust! - 306Brad - 04-04-2013 Can you mate up a decat and a different centre pipe with the standard back box on a 1.9 D-Turbo? RE: Exhaust! - Chris_90 - 04-04-2013 The back box is the most restrictive part so you want to get that out, just get some straight pipe cut the cat out weld a bit of pipe in and take back box off and weld pipe in there to sorted the center box is'nt that restrictive RE: Exhaust! - 306Brad - 04-04-2013 (04-04-2013, 07:07 AM)Chris_90 Wrote: The back box is the most restrictive part so you want to get that out, just get some straight pipe cut the cat out weld a bit of pipe in and take back box off and weld pipe in there to sorted the center box is'nt that restrictive Can find a subtle exhaust backbox, want it to be straight through but have a dummy box so i dont get any fuss from the police.. hmmm might have to email powerflow or something. Anymore suggestions on a straight through d turbo zorst? RE: Exhaust! - Piggy - 04-04-2013 just remove the centre box, replace that with a straight pipe...like £5 from a motor factors then use the centre box to replace the back box...using the bits of spare pipe and some jiggery pokery. basically for a tenner you can have a straight through that wont embarrass you or get bad attention and at same time see some gains RE: Exhaust! - 306Brad - 04-04-2013 LOL forgot how fun owning a french car was! bodged up tot the eye balls.. will have a play and see what i can come up with! |
