Oil cooler
Im considering getting a oil cooler before summer this year as i did have a few temperature issues last year when giving it some and dont really want these issues on track this year.
Would there be any reason why i couldnt put a 13 row cooler behind the radiator or is there not enough air flow there for it to do its job properly?
Mine is say onto of my intercooler, infront of the rad, but behind the grill.
Gets enough air flow there to keep it behind 95-100 normally
Yeah should be plenty mate unless you really ra*e it.
Ill be doing these soon
Can do mocal coolers plus the lines but not the sandwich plate
Niall fit it as I did on the diablo, long ways vertical but in front of the rad. It worked perfectly for mine!
Oil coolers in the ideal world should be in there own airflow, In real terms this doesn't happen that often so in front of the rad at worst.
Never buy a kit as the hose's are too short, I always mount the parts first and then measure the hose's, Again never use Hose clip or push fittings as they do and can come off, Crimped Braided is the safest option here.
Cooler wise you can get 13 row, but heavy or light duty, and different depth's make a huge difference on size
Miles I found quite the reverse; my hoses were too long!!
Your lucky, but as said most are the wrong length
got mocal too.the hoses are looooooooooooooooooooong
Not too fussed about the hoses being too long. There is a hydraulic place just up the road so will get them to alter them if needs be.
