283mm brake set up off a 206 gti 180 will it fit??
Basically going to get a 283mm brake set up off a 206 gti 180 tomorrow, i believe there the same set up as the gti6? am i right just bolt on?
Upgrading my d turbo
A friend of mine not on the forum has these on his dturbo
Pretty sure it's the same
(29-03-2013, 04:47 PM)Stephen Wrote: A friend of mine not on the forum has these on his dturbo
Just googled it says that they use a thicker disc 26mm i think not sure if that makes any difference to them fitting or not?
Theyre the same, disc maybe slightly thicker. Also the 406 283mm has a slightly thicker disc.
They do fit though
The 307 also has 283mm with the same disc as the gti6.
If your after some the same I have some calipers but theyre pink will need disc and pads
(29-03-2013, 05:20 PM)kentiiboii Wrote: Theyre the same disc maybe slightly thicker. Also the 406 283mm has a slightly thicker disc.
Im going to get some tomorrow mate just wanted to make sure they fit with the thicker disc and see if they caliper is the same/fit, if the sale falls though tho will pm u
Ok mate.. should fit all the same
Offset is different iv had a look into it as i was offered a set cheap but it didnt fit 307 HDI setup is the same and doesnt come with the gti price tag
www.prestige-auto-care.co.uk
(29-03-2013, 05:44 PM)Jenkosowls Wrote: Offset is different iv had a look into it as i was offered a set cheap but it didnt fit 307 HDI setup is the same and doesnt come with the gti price tag
So dose that mean they wont fit? Cos the offset?
just have a google for the gti discs and 206gti discs and compared the dimensions...then you'll know for sure
My cabriolet had a set of GTi180 brakes on, nothing out of the ordinary. The piston size might be smaller? Iirc, was so long ago I can't really remember! But they did fit straight on.
Edit: found the info Smile
206 GTi180 calipers require a thicker disc and have a 54mm piston, whereas 306GTi6 calipers have a 57mm piston Smile
[Image: Sig500x130.png]
According to jenks the offset is different also in this krisb for sale thread
http://306oc.co.uk/forum/thread-2897.htm...gti+brakes
he says they hit the hub because the offset
Or am i wrong?? to be fair not gona bother risking it will look for some off a 307 at scrappy
Like I say theres some in shed will need paint though make me offer
Not looking to buy at the min as got to get welding done but when I got some money will pm u
  Upgrading to 283mm brakes on Dturbo Hobo Ash 15 8,612 01-07-2017, 11:34 AM
Last Post: Hobo Ash
  283mm 307 Brakes on a S16 Pingaz 13 8,548 05-10-2016, 07:46 PM
Last Post: miles
  283mm Caliper donor vehicles mattsrallye 2 2,823 03-03-2015, 03:37 PM
Last Post: mattsrallye
