24-03-2013, 06:18 PM
hdi strut brace issues!!
Firstly, when does it do it. When you accelerate, brake, turn, what?
Put a jack under the engine and them remove the LHS engine mount, the chassis cup fatigues beneath them. Remove that bar over the top, take the 17mm nut off, remove the chock, then remove the bar mount itself, then rotate the engine mount using a hammer/screwdriver. Is there a hole, cracks etc. It's rare on a HDi but very common on a GTi6.
HDi Owner for 200k/9 years
24-03-2013, 07:04 PM
Only when turning hard left or right oddly
25-03-2013, 05:05 AM
Does it tend to do it when you're parking up or pulling away and on full (or almost) lock?
If so I'd put money on it being the top mount bearing......did you fit new ones when you lowered it or just use the original set?
25-03-2013, 08:00 AM
I had issues when fitted mine in the past was due to bolts in top mount. Sort of clunk sound when turning
25-03-2013, 11:57 AM
Where did you get the bolts from? If they aren't the right ones it makes some horrible noises
yup as said check your bolt lengths i had to cut some off my extended bolts as it was making a spring noise on full locks
25-03-2013, 03:29 PM
you need swampys extended bolts. or just some decent ones from B&Q
looks like he has replaced the T/M bolts
25-03-2013, 10:23 PM
The bolts are high tensile ones i had but there like an inch and a half long :-\
26-03-2013, 04:31 AM
the bolts you used could well be too long then mate
26-03-2013, 06:51 AM
More than likley, never considered the bolts could conflict the spring
26-03-2013, 06:52 AM
this ^^^ my bet is the spring top cup is hitting the bottom of the bolt when turning on tue bearing
26-03-2013, 07:44 AM
Cheers mate
| Vibration issues after strut brace installation | S16 | 14 | 6,927 |
16-12-2014, 02:11 PM Last Post: S16 |
| OMP strut brace adjustment nuts | lolsteve | 6 | 3,635 |
05-11-2014, 01:09 PM Last Post: Eeyore |
| Strut Brace Help | C.A.R. | 8 | 5,308 |
30-03-2014, 08:32 PM Last Post: Piggy |
![[Image: DSC_0190-Copy_zpsf093f84d.jpg]](http://i1038.photobucket.com/albums/a468/167gti8/DSC_0190-Copy_zpsf093f84d.jpg)
