15-03-2013, 09:11 PM
what do most do about the original fan connection and triple relay when fitting a slim line fan???
ta for input
ta for input
slim line fan
ta for input Wishes for more power...
16-03-2013, 09:44 AM
im sure there are threads and wiring diagrams up on this already
16-03-2013, 02:02 PM
ok...I'll keep searching....I searched, obviously didnt input the right words!
16-03-2013, 02:03 PM
Well basically you are either going to wire it into existing loom (ie two wires) or make up your own circuit on a switch which was discussed here recently
16-03-2013, 02:06 PM
I want it on current circuit...auto...
but its a single slim line...and theres two originally... thinking to just use the switched live...earth...via rad switch straight to the fan? just wondered if others had problems/wrong way to do it Wishes for more power...
16-03-2013, 02:22 PM
Just use the wires that come from the tripple relays to run a fan or 2 depending on how many fans you had as standard.
To test which is pos and neg pull the temp sender plug and bridge 2 of the pins and theyll start to spinn if they work then you can test them with a multimeter.
16-03-2013, 04:09 PM
My mate wired my rallte up with twin slimlines as per haynes manual twin fan with rad switch. Made a custom loom that worked a treat.
HDi Owner for 200k/9 years |
| Cooling slim fan Mod issue | 8soupapes | 10 | 8,895 |
29-10-2017, 05:13 PM Last Post: 8soupapes |
| Mounting slim line fans? | Mitch | 7 | 6,094 |
09-07-2013, 08:32 PM Last Post: Mitch |
| Slim line fans | cwspellowe | 5 | 4,795 |
04-06-2012, 11:06 AM Last Post: Eeyore |
