The Meatwagon: Missing, presumed..?
My door seals are knacekred so i'm pretty sure the constant moisture and non working heaters should help it rust!
But yeah, sounds like a plan. Shitty rusty interior ftw!
Hmm now what for the door cards...
none? Chequer plate?
Yes, chequer plate and rivets.
Right so that's sorted then.
the vw boys use saltwater baths to achieve the rust they so crave (not that it needs any encouragement on old vdubs anyway)
but yeah, soak bits you want to rust in saltwater for a few days till it rusts then rinse off and lacquer to stop it rusting into dust
Apparently beer gives different colours of rust too?
Turns out there's galvanised still on the wing which had made some, erm, interesting patterns?
Diesel rub it.
Ha ha quality!! Yeh metal bar as a dash sounds great
[Image: SDC10442-1.jpg]
Panels from motor factors rust Smile
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
I'm not buying a whole new panel just to rust it lmao
This is rusting. I'll get pics later during daylight, pattern looks awesome though
Needs moar pictures!
Will a rusty dash not be in some way a health Hazzard?? You might wanna check these things for insurance purposes!! Hate to be a stick in the mud... :/
[Image: Sig3_zpscd005eb1.jpg]
Is there nothing in the MOT about having a safe dash which wont cut your head open when you smash into it?
I'll put some pipe lagging over the edges then?
becausepostapacalypse
rusted Sheet metal wind deflectors???
Needs blood splatters on the bonnet. From where the zombies get in your way, trip to the local butchers and get some intestines. Throw at the car. Remove chunks and lacquer the f*ck out of it
(02-03-2013, 04:23 PM)Matt Wrote: Needs blood splatters on the bonnet. From where the zombies get in your way, trip to the local butchers and get some intestines. Throw at the car. Remove chunks and lacquer the f*ck out of it
OFT AYE! Hmm.. yeah definitely needs something but i have an a-bar coming soon, so that might be the order of the day.
Plenty done today, got too distracted by wiring though and didn't actually change the clutch cable lmao pics up when I can be arsed x
Ok, got some pics uploaded now.
First of all, i was supposed to have been sorting the clutch cable. Got a bit bored and distracted and instead went and grabbed myself a relay to wire up and fit the roof mounted spot lamps. They've been wired with help from the "fogs with main beam" but instead of a diode and feeding into the fog light circuit, the relay is instead earthed, so when the full beams are flicked on the spot lamps come on too. They've been wired in with an on/off toggle switch on the dash so not issues with Mr MOT.
Also wired up the hazard beacons, again just feeding from a live (permanent one this time) behind the dash and to a toggle switch.
I actually hate wiring though, PITA compared to some other jobs but oh well, all done now, especially now my little clock/temp gauge/voltmeter is wired in, replacing the crappy standard clock. Not sure how accurate temperature is on it, but voltmeter shows 14.2V with the engine running which is pretty normal. Handy thing to have to spot a failed alternator/battery Smile
Right, pics, no particular order, but there's a few of the rust that is getting along nicely too. I'll hopefully sort the clutch cable tomorrow. Maybe...
[Image: 382362_495758810472158_1608821723_n.jpg]
[Image: 555458_495758820472157_2052335049_n.jpg]
[Image: 540795_495758830472156_259699426_n.jpg]
[Image: 421537_495758847138821_2111505647_n.jpg]
[Image: 529856_495753927139313_200781359_n.jpg]
[Image: 313339_495753997139306_1122161510_n.jpg]
[Image: 601552_495754143805958_506103379_n.jpg]
Epic as always Chris. Now fix the clutch cable Tongue
f*cking love it !!!!!!!
Sick! Needs grills over the headlamps tho
(02-03-2013, 06:43 PM)sammykins Wrote: Sick! Needs grills over the headlamps tho
I was thinking of getting some headlight protectors and painting the stripes on, like the spot lamps?
I have an A-bar coming next week too so hopefully can bodge that on..
Thats ace Smile liking this alot
Yeah, that could work, I've a set if you want?
Possibly, spent a fortune this month though so laying off the props for a bit, i'll let you know though sir x
Cool beanz man, they're just sitting in my room anyhow
dude, put the license plates right..
LIKE!
[Image: sign.png]
↑ Project ↑
(02-03-2013, 11:32 PM)Seid Wrote: dude, put the license plates right..
LIKE!
Don't do this! Wonky plates ftw!
(01-03-2013, 07:01 PM)cwspellowe Wrote: Jenks.. shim metal?
That's not a bad idea though, would mean I don't need bracing of any kind as I can rivet plates over the original dash, and wouldn't be any hassle having to relocate wiring etc
Metal that's .5mm comes in rolls in tins. You use it to shim gaps to make it tighter. Or copper sheeting if your feeling rich
www.prestige-auto-care.co.uk
Meatwagon kind of sounds like a gay men's nightclub?
[Image: sigjpg.jpg]
Serious.
