Fuel IN banjo
Fuel IN banjo
Any one no where i can get one or have one for sale? Iv moded the lucus fuel return banjo bit it leaks and i cant be assed gettin air in the line every 10mins any help is appricated
Cheers Jamie
Hydraulics places possibly good motor factors
www.prestige-auto-care.co.uk
theres a couple on ebay...came across them last night
Really? Got a link? I had a look the other day but not really sure what im looking for TBH
theres so many on ebay...all depends on size...
measure the inner diameter of the banjo if you can and the size of the pipe fitting...
IE m18 hole and 8mm pipe
all you then search for is "pump banjo" and find your size
Yeah will give it a go when i get home. Pretty sure the bolt is M10 anyway. .
Righty hoe cheers
Are you sure its the banjo leaking and not just lack of copper washers? I know I started having problems with leaking there and I just needed new copper washers
I would say it's more like M12, either that or a completely random Bosch specific thread size/pitch.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
(27-02-2013, 01:31 PM)Harky Wrote: Are you sure its the banjo leaking and not just lack of copper washers? I know I started having problems with leaking there and I just needed new copper washers
Very sure. The banjo from the lucus has 3 outlets. I tryed to cap the two i dont need but they havent sealed. Its a right lash up and im not going to continue to try and bodge it.
(27-02-2013, 03:40 PM)Ricky Wrote: I would say it's more like M12, either that or a completely random Bosch specific thread size/pitch.
Yep you right ricky. It is a M12.
Iv now ordered x2 M12 8mm pipe banjos. A length of leak off pipe. And a length of fuel line. So jobs a gooden
I ended up getting an engineering company to make me one for a bosch pump. Cost me about £5
Puglove did the bolt you bought work ok? Was it standard M12 x 1.5?
GT2052s DTurbo
OEM+ HDI Estate
Project thread
  Bosch Banjo bolt, m12 x 1.5? billythekid 2 2,517 20-03-2014, 12:11 PM
Last Post: billythekid
  banjo bolt fitting Ben 2 2,389 12-05-2013, 03:05 PM
Last Post: Chris_90
