C5 bottom pipe placement
Does anyone have a picture/diagram/description of how the c5 bottom pipe fits for FMICing?
Thanks
Ian
Need to remove previous pipe which we had to saw it in two to get it out, sounds easy but took awhile due to space limitations
The c5 pipe then connects to the turbo and then need to push the rubber sleeve on as hard as possible then tighten the jubilee clamps, found its easiest accessed to tighten by removing the driver side wheel and getting a screwdriver to it from the side by the shocks/coilovers
The pipe should then line up with the gap down the side of the sump
[Image: mcetg0.png]
so it will come be on the right hand side of the sump when im looking from the front. thats what i thought, just wanted to check before buying shiny goodness.
You've got it. Smile You may have to cut some off the end of it so you can get a bend in before the radiator, depends on your set-up though.
Im sure i can sort them when i fit it. When doing stage two is it recomended or needed to have a manual control boost controller fitted?
Just recommended, makes life a bit easier.
Depends on your turbo tbh, the ko3 is a piece of piss to adjust
Question Bottom turbo pipe (updated with pics) questions added highwayman306 15 9,328 02-10-2015, 07:35 PM
Last Post: fgrc76
  406 bottom turbo pipe!!! Donkeybubles 9 5,681 22-11-2013, 01:26 PM
Last Post: reckord
  FMIC HDi, bottom boost pipe? callumcull 6 4,518 21-11-2013, 06:18 PM
Last Post: Poodle
