TD04 Spool
How would you go about making the spool of a td04 kick in at much lower revs? Could it be done via the pump? And would they be anywere near that of a kkk for example?
Discuss..
I think you need to read up on how turbos work.
On the 306 waiting list.
If you want it to kick in faster get a smaller turbo Smile
Td04s take longer to spool but worth the wait 100%
306 HDI, soon to be XUD
Unless you're planning on supercharging, or plumbing a much smaller turbo to pull through it, the answer is no.
They're old tech turbos, designed to work on a petrol engine and give the flow for power higher in the revs, so the application is not perfect on an xud, however it's pretty good for a cheap relatively easy to install turbo.
If you want more spool earlier in the revs, you want to be looking either at much newer gen turbos, or VNTs. Basically something more tailored to your application. However the above 2 options carry their own drawbacks (price & control of the vnt mechanism respectively).
Basically if you want something that's better suited you need to do a lot of research!!
but i want the moon on a stick.....give it to me goddamnit!!! lol
i'm heard that spool time of a td04 is pretty similar to a k14 anyway
(21-02-2013, 11:45 AM)Mattcheese31 Wrote: but i want the moon on a stick.....give it to me goddamnit!!! lol
The spool time on my td04 was a bout 300rpm after my k14.. And it blew all the way to 5.5-6K.
People that moan about spool time being to late on a TD04 either need to get a better gov mod or MTFU and rev it higher!
Lol, this ^
Everyone harps on about how Diesels don't rev, so they stick on a TD04 and then complain that they have to rev the bollocks off it to make it go anywhere.
LOLWAT.
GT2056 ninja
GT2259S ftw!
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
(21-02-2013, 12:03 PM)cwspellowe Wrote: GT2056 ninja
I'm surprise there are any around after your antics!
Holset HX60
/Mechsman
On a serious note where did that character go in the end?
(21-02-2013, 07:25 PM)Ed Doe Wrote: Holset HX60
/Mechsman
The what?
  spool turbo gt2056s niciou 11 7,244 05-07-2016, 08:12 PM
Last Post: Piggy
