spool turbo gt2056s
hi to all the world
My brother has a zx td 1.9 and a turbo t2- t25 he want to know is how a spool gt2056s ?
es that there are more effective than a td04l ?
and are as a gt2056s fmic with a pump and a 11 mm es that has a turbo lag for XUD 1.9 ?
thank you
Very good turbo.
Spool up much sooner than you would expect.
Can't abuse it like a td04 or run such high boost...but its so efficient you wont need to
(03-07-2016, 03:33 PM)Piggy Wrote: Very good turbo.
yes I have seen your videos on you tube piggy is 1.1 bar you walk very well right after 2.1 12v has a thy as
toujour engine you will work better now that a 1.9 td with identical turbo pressure but I was surprised.
d after you on 1.9 td if there is a 1.5 bar how r / m it will get 1.6 bar
es that the turbo will hold up enough to longtemp 170 hp or 180 to 1.6 bar will be robust enough?
person can tell me how I have rpm 1.5 bar with the pump gt2056s with a good adjustment?
I have no idea what that means Undecided
(05-07-2016, 10:52 AM)Piggy Wrote: I have no idea what that means Undecided
lol
I will try to explain otherwise
for example my td04l-15t gives me 2 bar at 2800 tr / min
the gt2056s if I mounted a pressure 1.5 1.6 bar how r / min J will have 1.6 bar (2200 or 2500 tr / min?)
you know ?
Before then...
But all depends on the way the engine is setup
(05-07-2016, 03:17 PM)Piggy Wrote: Before then...
is true that this is a matter of adjustment but for example my turbo well I know that if I want 2 give the bar it not me below as 2700 tr / min even by setting j not arrive below this performance the only thing I wanted to know if the gt2056s spool rather than 2700 tr / min if a lower gear there are more efficient than the td04l?
It is worlds apart
Far more efficent than the td04l yes.
Much faster spool time.
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
(05-07-2016, 07:44 PM)Danny Wideboy Wrote: Far more efficent than the td04l yes.
super thank you so its going to change her life to my brother he's a little really effective t2-t25 as turbo.
I have one last question are the gt2056s can get behind the engine with the exhaust manifold of origin
on a zx td there is enough space behind the engine?
Yes you can just about
  GT2056s oil feed question simonh 2 3,286 21-02-2018, 05:54 PM
Last Post: simonh
  Problem turbo pressure gt2056s niciou 6 6,821 30-03-2017, 06:41 PM
Last Post: niciou
  lb/ft max gt2056s niciou 0 2,249 13-03-2017, 10:31 AM
Last Post: niciou
