19-02-2013, 07:40 PM
Make the stereo turn off when the ignition goes off as I have to turn it off manually (now it works lol)
Can I
19-02-2013, 07:45 PM
Usually simply a case of swapping the red and yellow wires. Also usually bullet connectors for this purpose, assuming you're running an aftermarket HU
19-02-2013, 07:46 PM
It's a jvc one but the standard one I took out was the same
19-02-2013, 07:57 PM
swap the red and yellow. problem solved.
19-02-2013, 07:59 PM
move the shunt fuse
19-02-2013, 08:00 PM
Forgot about the fuse, that's more likely what's going on if it was like it with the standard unit
19-02-2013, 08:05 PM
Yeah the standard one was the same what's the shunt fuse ?
19-02-2013, 08:08 PM
shunt fuse is marked HS you remove it and move it 1 slot up or down
im guessing yours is in the down position ![]() what the fuse does is changes some ign powered things to be powered without the ign on like cigarette lighter and radio
19-02-2013, 08:25 PM
(19-02-2013, 08:25 PM)cwspellowe Wrote:(19-02-2013, 08:18 PM)cully Wrote: shunt fuse is marked HS ha ha looking at the fuse again it is SH read left to right upside down or right way ![]() wow wow hold on it may be the fuse 23 the one thats off set in the picture above (yellow 20amp)
20-02-2013, 09:18 AM
For me its fuse 1, very left most fuse, has 2 positions and is for radio
20-02-2013, 09:59 AM
I have a 30 fuse fuse box and fuse 1 has to different positions
20-02-2013, 02:51 PM
Should be fuse 1 then, move that to its other position and it should work like you want it to
20-02-2013, 03:51 PM
6 years of 306 ownership several 306's and never noticed this. But makes sence why my radio never went off in my old 6 and the fuse was in a weird place.
20-02-2013, 04:17 PM
(20-02-2013, 03:51 PM)puglove Wrote: 6 years of 306 ownership several 306's and never noticed this. But makes sence why my radio never went off in my old 6 and the fuse was in a weird place. Same here that and the petrol cap holder lol
20-02-2013, 04:22 PM
My shunt fuse only fits one way lol
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
20-02-2013, 06:51 PM
Ha ha you as well !!! If you look inside the flap there is a spot to put your filler cap! So you don't lose it, can't shut the flap when it's in so can't forget to put it back in lol had mine 5 years before I found out ha ha
20-02-2013, 06:54 PM
(20-02-2013, 06:51 PM)puglove Wrote:(20-02-2013, 04:17 PM)Jonny b Wrote:(20-02-2013, 03:51 PM)puglove Wrote: 6 years of 306 ownership several 306's and never noticed this. But makes sence why my radio never went off in my old 6 and the fuse was in a weird place. shhhh dont tell him the secret holder for the fuel cap
20-02-2013, 06:56 PM
How can you not know bout the holder, it's like the best part of the car
20-02-2013, 07:03 PM
20-02-2013, 07:27 PM
WOOOOOOOOOOOOOOW WOOOOOOOOOOOOOOOOW WOOOOOOOOOOOOOOOW.....................................
Im going out side to try !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! AAAAAAAAAAAAAHHHHHHHHHHHHHHH so excited
20-02-2013, 07:31 PM
how did i not notice this?!?!?!? Shame mine is snapped off
Knew i should of taken the flap off the 1.8!
20-02-2013, 07:33 PM
See now you know the secret of the fuel cap holder you have to be initiated by Samass!!! Into true 306 ownership!!
You won't know where or when!!! But it will happen!!!!! Lol
20-02-2013, 07:38 PM
Just been outside checking all my 306's thats soooo cool, i can get rid of my 7 spare caps now
20-02-2013, 08:41 PM
LMAO you boys are easily pleased
