19-02-2013, 07:07 PM
Does anyone kno if id see a noticeable gain with a str8 through exhaust on a hdi? N any other small mods I can do to see a gain? Apart from a map?
Noticable gain
19-02-2013, 07:09 PM
You'll almost definitely see a gain in spool time and response, maybe a slight increase in top end power too. Most noticeable though will be the faster spoolz
19-02-2013, 07:10 PM
(This post was last modified: 19-02-2013, 07:10 PM by 4WayDiablo.)
Not a lot really they only really amplify increases from the likes of maps
But the basic ones Induction(be it panel or cone) Exhaust (free flowing) Egr delete
19-02-2013, 07:17 PM
How do I go about gettin rid of egr?
19-02-2013, 07:26 PM
Unplug the blue plug over by the brake servo pretty much does the job.
Proper way is to black it with a little plate you can pick up on the bay
19-02-2013, 07:33 PM
you can just unplug it. Look for a guide somewhere. Remaps will obviously make the most difference!
19-02-2013, 07:50 PM
How much am.i lookin at for a map?
19-02-2013, 09:51 PM
Exhaust makes a big difference to the drive on a stage 1, won't notice much difference without a map though. I shouldn't bother with any changes to your induction, the standard system is pretty capable and the other options all seem to have a tendency to munch through mafs.
Map will set you back ~£120, depends who you go to. My Whippy and HDi Tuning (pro_steve) come highly recommended, also TB205.
20-02-2013, 10:26 AM
IMO intake is a waste of money on a HDi, they can upset sensors and the flow of a standard OEM paper filter is just as efficient!
Get the map on ~ £100 Decat pipe ~ £50 (brand new) plus fitting if required £40-60 These are the basic things you should start with, but always combine them with a good service and high quality (if not OEM) filters and fluids. Then go from there... Disclaimer: The above is not to be taken to heart and is probably a joke, grow up you big girl.
20-02-2013, 08:06 PM
Only thing i would have to add to that list is a backbox to midbox conversion, made a noticeable difference on mine. Plus, for the sake of a tenner for a scrapyard mid-section and a little time with a grinder and welder, you may as well lol.
20-02-2013, 08:52 PM
pro-steve remaps for £75 just need the tools to upload to the ECU
http://www.ebay.co.uk/itm/Peugeot-206-30...0866834097 |
| hdi boost gain | smokey | 10 | 4,746 |
19-12-2013, 01:01 PM Last Post: Poodle |
