boost gauge nipple
boost gauge nipple
Just wondering where you got the nipples from for the hdi boost gauge.
Got the inlet elbow now so thought I could drill and tap it while its stood.
Cheers
Ooo I want to know this! Going to be purchasing a boostguage soon Smile
Why you getting a boost gauge on a stage 1?
You are still stage 1ing it arent you?
Ebay mate, search for threaded barbed hose connector
Or your local nuts and bolts supplier or marine stores or hose specialist, etc... support local business and all that jazz.
Legend mate cheers
(16-02-2013, 01:19 AM)Oil-burner Wrote: Why you getting a boost gauge on a stage 1?
Just fancy one. Then if I do go stage 2 it's there.
Gonna have to rip the elbow off tho.
You found your ecu code yet?
(16-02-2013, 08:05 AM)Oil-burner Wrote: Gonna have to rip the elbow off tho.
Yeah got ecu code. It all matches my map so just waiting for a day off to service it then its ready. Big Grin.
You jammy shit!
You're very lucky to get another with the same codes mate.
Let me know when you're ready and we'll get it chucked on
It's good practice to run a boost gauge the moment you start tuning, just to be on the safe side.
(16-02-2013, 12:45 PM)Oil-burner Wrote: You jammy shit!
I know that's what I thought! Well when I have a day free I got a list of stuff to sort so will let you know.
That's why I want a boost guage. For safe side. Plus I've never had chance to fit one Smile.
And because racecar. Big Grin
(16-02-2013, 01:20 PM)Poodle Wrote: And because racecar. Big Grin
Defferntly because racecar! Big Grin
The torque app on my phone reads boost pressure but not sure how accurate it is.
Think its reading about 14.7psi atm on stage 1.
I don't have android though. Smile
Where does it read boost pressure from? Can you get a sensor for it or something?
Ive no idea tbh I was shocked when it came up but it seems fairly accurate tbh
This is what I did to pick up boost pressure.
[Image: SL7401571280x768.jpg]
I used a push fit pneumatic fitting with an m6 thread on the EGR blanking plate.
(16-02-2013, 04:25 AM)gareth7 Wrote: Ebay mate, search for threaded barbed hose connector
What size do I need?
it depends on the size of the hole and what size tapping set youve got! i honestly wouldnt bother with one of the barb ones. Just get the one with bolts through and has a seal on both size! I bought a barb one and couldnt get a tapping set big enough so i bought one of these in the end!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...1044645661
(17-02-2013, 06:01 PM)DeeTurbo Wrote: This is what I did to pick up boost pressure.
Now that's a tidy install, like it. Been looking at pneumatic connections myself after being fascinated with the one's on the compressor loop at work, didn't think of applying it like this though, nifty.
(17-02-2013, 07:03 PM)Poodle Wrote: Now that's a tidy install, like it. Been looking at pneumatic connections myself after being fascinated with the one's on the compressor loop at work, didn't think of applying it like this though, nifty.
Thanks and yeah that's where I got the idea from, we use a bit of pneumatics at work.
It makes connecting and disconnecting so much easier as there's no messing with hose clips.
(17-02-2013, 06:52 PM)SRowell Wrote: it depends on the size of the hole and what size tapping set youve got! i honestly wouldnt bother with one of the barb ones. Just get the one with bolts through and has a seal on both size! I bought a barb one and couldnt get a tapping set big enough so i bought one of these in the end!
This is the one I bought ^
HDi Cabby Project Click
  Boost gauge BoldieRob 8 4,320 01-02-2017, 09:14 PM
Last Post: kyler000
  Boost gauge and stock pressure JTaylor2005 16 7,494 27-08-2015, 09:43 AM
Last Post: JTaylor2005
  Recommendations for boost gauge and fitting kit 306rhys 6 3,880 30-07-2015, 07:56 AM
Last Post: Poodle
