12-02-2013, 01:37 PM
Which gti6 clutch kit are you using?
Stage 2 Clutch Kit
12-02-2013, 03:25 PM
12-02-2013, 04:54 PM
The gti6 kit is the same as the XUD clutch kit, good for around 270lb/ft i'd imagine, would've thought the box would've been converted to pull type to use it though?
12-02-2013, 06:41 PM
Was going to say the above, did he do the full conversion then? FYI a standard Gti6/dt clutch will only take fractionally more than the equivalent HDi item, any difference is purely down to the type of mechanism.
12-02-2013, 08:40 PM
(12-02-2013, 06:41 PM)Poodle Wrote: Was going to say the above, did he do the full conversion then? FYI a standard Gti6/dt clutch will only take fractionally more than the equivalent HDi item, any difference is purely down to the type of mechanism. Couldnt honestly say tbh mate, but i know he had a gti6 in now, not sure if he done full conversion but i will ask
19-02-2013, 10:47 AM
Ah so is this stage 2 mapped? Did LK performance give you a refund on the clutch
19-02-2013, 11:27 AM
I am now running a full stage 2 remap I ended up buying a cg 5 paddle Motorsport clutch for 275 pound + postage and I got to says its awesome its really light holds the full power and I was quite worred because people was telling me that paddle clutch are on\off but it's really not that bad I can pull away fine there is a little bit of a snatch but I've only noticed it on a very steep hill but still can pull away fine I really recommend it!!
19-02-2013, 09:58 PM
No refund from LK so far, will be very annoyed if i dont get the refund tbh, so fingers crossed
22-02-2013, 07:26 AM
I've taken a shit in Buckingham palace, does that make me royalty?
| Best clutch for stage 2 | L16rye | 4 | 4,667 |
15-11-2016, 06:36 PM Last Post: Poodle |
| Clutch kit Stage 2 ? | MrBigMac | 54 | 29,700 |
28-08-2015, 06:30 PM Last Post: ct-hdi |
| Stage 2 Clutch | Chris HDI | 15 | 9,608 |
23-08-2015, 08:28 PM Last Post: ct-hdi |
