lowering front
lowering front
wanting to lower my 306 1.4, wanted to lower it about 50mm but very hard to get in ireland, found some 60mm saxo springs anyone put saxo springs on 306 before and any pictures of it done? thanks
[Image: 13073041_458228241037318_1249062425_o_zpsoh6qf7gu.jpg]
If you put -60mm Saxo springs on a 306, it'll be down around 80 due to the different spring rates. This really isn't ideal and could be dangerous. It has been done, especially in Ireland but you'll have to do some searching.
If you're considering 60mm Paxo springs, why not just get 60mm springs actually made for a 306?
40mm saxo springs might be closer to what you want? but again not recommended
[Image: mcetg0.png]
ok thanks for the info, ill keep an eye out for some for the 306, thanks a mill
  Lowering the front Davidwheaty 10 5,749 25-08-2015, 10:25 PM
Last Post: Davidwheaty
