Mechanical speedo cable off a zx!
Wanted: Mechanical speedo cable off a zx!
My motorfactors told me today that they weren't doing speedo cables any more?! lol
I dont fancy going to the dealer, anyone have one lying around. You'll have to be able to post it since im in N.I.
Thanks.
Bump, busting for one of these!
I'm breaking a Ph2 DT, would that have a mechanical speedo cable?
(06-02-2013, 02:49 PM)bigcheez2k3 Wrote: I'm breaking a Ph2 DT, would that have a mechanical speedo cable?
I was under the impression it was just older phase 1s and ZXs that had mechanical ones. If you get a chance you could check but dont go out of your way!
Bump!
Have you spoken to a motorfactors over here to see if they would post to you? Or just online.
(13-02-2013, 09:26 PM)PE02KHG Wrote: Have you spoken to a motorfactors over here to see if they would post to you? Or just online.
Just tried my local, getting a bit desperate so ill ring about soon. I've a bad feeling it will be about £50 if I get one new. Can't justify that if I can get one second hand that will do the exact same job.
Ill have one in a couple days for you if you still need one.
On the 306 waiting list.
(26-02-2013, 12:41 AM)Jake Wrote: Ill have one in a couple days for you if you still need one.
Good man, keep in touch!
I should have one, I'll check later.
Bugger.
Went to peugot today. He has access to the citroen part numbers and diagrams. We found the cable only to find its no longer in production. Looked at the 306 one on the computer and its completely different.
So that's me a bit stuck. The zx in my local scrappy has an electric speedo for some reason. Sad
Convert to electric by robbing all the bits off the one in the breakers?
  Wanted: Ph1 dt cable speedo clocks Craigus 2 2,168 13-02-2014, 09:28 AM
Last Post: Craigus
  Wanted: Mech speedo cable and drive Nath140889 2 2,305 18-04-2013, 12:35 PM
Last Post: Nath140889
  Wanted: Ph1 DT speedo cable Jake 6 3,847 08-01-2013, 03:02 PM
Last Post: aggyj17
