Another XUD
Another XUD
#31
Yeah, straight swap.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
But only the pump and the injectors,right?
What do you mean? The older full manual pump will go straight on, along with the injectors. Although you can use your current injectors.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
And what about the smart injector?
you mean the one with the wire? If so that will be fine just cut the wire off, its not needed. I have a 406 XUD in my 306 and I'm running a manual pump with the original injectors.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
leave the injector etc in and get ppo then you really play with the advance springs/ip.
what is ppo?
Peugeot planet, its a diagnostic interface that will let read live data from the engine ecu like rpm/advance/tps, most go by ear with advance/dynamic advance.
Thanks ;]
Another question:
Whant nozzles I must use?...from 2.1 maybe? Smile
