Threads: 18
3
Not had a lot of time to do much to the girl.. she still gets a weekly wash and clean but I haven't even used my carnuba wax or buffing pads yet but she does gleam
Plus I work for comet so I'm saving rather than spending... the clutch won't be going in anytime soon, if at all as id like a full helix, plus she needs another crank pulley, aux belt and a oil change... just trying to get her through winter!!!
Threads: 170
5
Car Model/Spec: xud 1.9 dturbo
is the pulley noisey again then?
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 18
3
Its not running true that's why it sounds like its knocking... coming from crank anyway
Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Given 3 thank(s) in 3 post(s)
(21-11-2012, 05:15 PM)Arron Wrote: Not had a lot of time to do much to the girl.. she still gets a weekly wash and clean but I haven't even used my carnuba wax or buffing pads yet but she does gleam
Shit news about comet hopefully your job will be safe, hope car comes together eventually
Threads: 18
3
Cheers mate. I have savings but a combo of Christmas, potential job loss and a little boy means spending on the car has to, well limited
Changed the aux belt and crank pulley now, no squeeking for another 6 month!! The cars running well at the minute, just trying to get it through winter then the mods can commence again!!!
Arron
Threads: 18
3
Decided to load my spare stage 2 map on, no rev limiters or launch control, with around 240lbs/ft.
The clutch likes this map better, the car drives better if I'm honest, the delivery is less aggressive... but at around 3600rpm in 3rd and 4th it feels absolutely numb, changing up brings you straight on boost, so loaded my original s2 map on... the same.... tried my s1 map.... same... looks like I've chewed the maf again!!!
Threads: 51
4
Car Model/Spec: Did Have Track Prepared GTi 6
looks really smart with the whole wheel and car colour combo mate!
Threads: 18
3
11-12-2012, 11:56 AM
(This post was last modified: 11-12-2012, 11:57 AM by Arron.)
Cheers mate..... tried to make it an OEM/stealth colour scheme
Threads: 18
3
May aswell update.
Finally got round to fitting some rally blanks. Also decided to twice machine buff t-cut and carnuba wax the whole car. Took of us around 3 hours in total in the cold. I've took a few pics
I'll update again once I have a clutch.
I'm hoping to put it on a rr soon too
Threads: 77
15
Car Model/Spec: oem+ phase 3 astor 6
Looking good chap, rallye blanks suit it alot
Threads: 18
3
15-01-2013, 06:32 PM
(This post was last modified: 15-01-2013, 06:42 PM by Arron.)
Ok so I've ordered a clutch. I was set on a helix like warlord but I called helix and they say that clutch is only good for 260lbs/ft. So they quoted me for a paddle, which took the total to 475 Inc delivery and vat!!
So I decided to look at the berlingo Sachs 3 piece kit. Its highly rated by pipps on .net and a few others. But to make sure it holds I've ordered the paddle plate that whippy used. Come to £365 in total. The paddle plate has to be sent from Germany so its around a 10 day wait. Then fitting.
I've also ordered some fuel cover strips and front/rear badges in anthracite with silver lions on the badges from Gareth just to freshen it up
(14-01-2013, 09:32 AM)sam Wrote: Looking good chap, rallye blanks suit it alot
Thanks dude. Like how your cars coming on too
Threads: 77
15
Cheers dude hopefully itll be on the road thursday
Threads: 178
28
Car Model/Spec: HDi!
Given 1 thank(s) in 1 post(s)
Did they say how much the helix paddle will hold?
I got mine dead cheap really. Coming on nicely aaron
Threads: 18
3
15-01-2013, 06:59 PM
(This post was last modified: 15-01-2013, 07:01 PM by Arron.)
Sachs say their unable to put a rating on it Sean, also depends on the clutch cover used with it which is why I went for the berlingo Sachs kit. But I'd imagine anywhere between 280-300lbs/ft. That's what whippy claimed he was running
Cheers
Threads: 178
28
Did helix not say?
I suppose if their standard clutch will hold 260 then can expect it to hold well over 300
Threads: 18
3
Oh the helix paddle. Sorry mate I don't know what I was reading. They rated that at 300lbs/ft+. Is yours fully bedded in? How heavy is it over standard?
Threads: 178
28
Probably not fully bedded in to the power yet. Done a few hundred miles on s1 though, but I'm not hitting Max boost yet cos of my leak.
Don't feel massively heavy over standard but mine was quite heavy anyway.
You get used to it. And its either on or of when you first get it, hard to get control, just got to give a bit of throttle and b really gentle in traffic!
Awesome when your giving it beans though, it loves it! Downshifts are awesome with it, Andy will tell ya!!
Threads: 18
3
Shut up sean I'm already giddy I really can't wait to finally use launch control properly!! Are you at fcs this year??
Threads: 343
15
Carnt wait to see what this gives out on the dyno, defo gone down best route with the belingo clutch and paddle plate, think you will be in need of 2 front tyres once its mapped propaly lol
Threads: 18
3
18-01-2013, 09:59 AM
(This post was last modified: 18-01-2013, 10:00 AM by Arron.)
Me neither Chris.... should hopefully be good to hold 300lbs/ft
Just bought a 307 flip key and a 206 gti180 steering wheel. I can't find a guide for the flip key so I'll take pics and make one.
Threads: 178
28
18-01-2013, 10:02 AM
(This post was last modified: 18-01-2013, 10:02 AM by Just Sean.)
I'm sure I've seen one. Might be on .net though.
Can you still use c/l with the flip key
Threads: 18
3
Yup... wel I'll be looking to anyway.
I can't find it Sean. I'm sure I'll Suss it. I think it just sits at a different angle/height... probably needs plastic moulding
Threads: 18
3
18-01-2013, 04:27 PM
(This post was last modified: 18-01-2013, 04:33 PM by Arron.)
Just a pic of the crank pulley that's going on with the clutch. It looks solid to me, its the 307 jobby that poodle kindly linked me up.
Here's how I've finally fit the hks onto maf and the onto the Turbo pipe...
Threads: 18
3
23-01-2013, 07:09 PM
(This post was last modified: 23-01-2013, 07:13 PM by Arron.)
Fit the 206 gti wheel earlier. Little touch I think
Question z.. I've resistored round the air bag light, but the air bag connection looks like it will for, wondering if anyone can confirm it works across the models
Threads: 236
36
Car Model/Spec: '01 HDi DTurbo
I saw a GTi180 steering wheel on eBay and thought the same thing. I wonder if anyone knows? Trouble is, if you're wrong it's an expensive and potentially dangerous thing to find out!!
Looks good. Airbag is a funny old shape though!
Threads: 77
15
Loving the steering wheel dude
Threads: 18
3
I thought the connections were going to be different. I was going to try it but I suppose I'm just a shitty bum
Chris feel free to buy one and try it...
Threads: 236
36
F*ck that, I wouldn't want to damage my pretty mug.
Maybe get the MIL to test it...
Threads: 3
Car Model/Spec: 306 cabriolet
It works well. But you need to make a new hole for the cable/connector to keep signal-stalk-actuator working. It has to be 9 o'clock position in 306 and not 6 o'clock position like in the 206.
Important!!!! you need a pre-facelift airbag-steering-wheel with the screws to fix the airbag. The other models of multiplex models with springs to fix the airbag have an other offset and can-bus-signal. =won't work in the 306.
Threads: 18
3
I think mine is pre facelift... thanks for that
Also the flip key come today... doubt I'll be using it tho. The blade will need cutting but getting the remote lock board to sit in looks tricky.. looks like it will have to sit in at an angle.. Its the back that isn't wide enough due to the space needed for the key to fold in. Maybe with some plastic welding its possible but I doubt I'll be having a go anytime soon
