Different water pumps
Just noticed that there are 4 different water pumps, how do i know what one is for a D8a
go on ecp website, type in the reg and it should say?
i dont have a reg of a car with a d8a, my car was a dhy orignaly
Hm all the xud ones are the same...infact all the XU ones fit each others....some are plastic / some are metal though.....not sure why there wuld be four different ones listed...
[Image: sigi-2.png]
service box says they range from DIAM(diameter i think) 70 to 71.5, the one i have fitted to mine has two gaskets behind it a it was touching on the block when i tightened the bolts up?
i had this happen to one that had done less than 50 miles
[Image: DSC00823.jpg]
Hm, there may well be differeances that im not aware of then.....The casting is certainly the same as ive ran S16 pumps on mine before etc...
[Image: sigi-2.png]
Was there any reason for trying other pumps? anyone know a reg for a 306 that was original fitted with a D8a? want to go into peugeot with it and ask them why there is 4 types and one i need
Just use any? My old one was N967 WJW if you want to use that?
That will do, il go in when i get a chance
  FAI Water Pumps RAW 12 9,913 18-02-2015, 12:13 AM
Last Post: vinny
  "Cheap" new water pumps (£15) silverzx 22 15,334 11-04-2014, 05:36 PM
Last Post: ConorTRG
  What pumps are these? bobertmate 8 5,369 16-01-2014, 11:54 PM
Last Post: Mal
