Rear view mirror
Has anyone fitted a auto dim read view mirror into a 306?
Yep, mines from a 406. All it needs is a 12v live and earth, there's a 3rd wire to switch off dimming when in reverse but I never bothered as it needs a feed from the reverse light.
sweet...did all 406s have it??
have to admit...seems bit lazy though!
Mines from a C5
(27-12-2012, 03:48 PM)cwspellowe Wrote: Yep, mines from a 406. All it needs is a 12v live and earth, there's a 3rd wire to switch off dimming when in reverse but I never bothered as it needs a feed from the reverse light.
Ive got the same. Nice as it slides straight onto the windscreen with no modification and its slightly bigger than the standard 306 mirror
sweet little mod
anyone know which c5/406 models these came in?
Mines from a 406 aswel. What did you use for the backing on the window?
Cully did a guide on this if its any use to you. Smile
http://306oc.co.uk/forum/thread-1302.html
http://www.ebay.co.uk/itm/CITROEN-C5-INT...4abf27b5b5
the same seller i bought mine from is still selling them
And mine^^
I hang got a rain sensor.
curtisy light has a live feed i believe wire it to that
True. What could I use on the back of it as the rain sensor has a tint to it?
the black tint is like a black sticker of spots I'm guessing you could use black vinyl or a sun visor strip
Good idea batman
is it diff fitting for the ph1??
(27-12-2012, 09:49 PM)Piggy1987 Wrote: is it diff fitting for the ph1??
Shouldn't be as You would just wire it to the centre light as I'm gunna do.
yeh but the mounts look diff
Ive been searching scrappies for ages for a peugeot auto dim mirror to no avail, thet seem to be the first thing to go off a car.
might have a look into a mercedes one as almost all mercs came with auto dim mirrors after 2001 if not earlier
(27-12-2012, 11:20 PM)Piggy1987 Wrote: yeh but the mounts look diff
Use the ph1 mount then, just drill a small hole in the ball to feed the wires through
ok....nice one.... Smile
I've thought about this and I'm gunna try it today if I can find the right drill bit and spare wire.
as all the others have said. I have fitted both a C5 and a 406 mirror. The 406 is a bit too wide and may catch the sun visors. C5 one is the way forwards!
  Brake light switch parts exploded view pug306driver 11 9,364 13-12-2021, 06:11 PM
Last Post: Mighty306
