photo/video thread, td04/t25/gt22 etc
(26-12-2012, 12:50 PM)Ricky Wrote:
(26-12-2012, 12:04 PM)Ben Wrote:
(25-12-2012, 03:14 PM)Ricky Wrote: Garrett GT2052 removed from a Merc 2.2 diesel. On T2 manifold, vacuum actuator replaced by modified TD04 actuator. Custom downpipe with 3" elbow with v-band connection. Will be running 18-20psi.
[Image: IMG_1114.jpg]
[Image: IMG_1133_zps5eaede62.jpg]
Car's not on the road yet because of brake problems Sad Once it's going it should be a pretty epic turbo for the B roads.
Guess that took a bit of bulkhead modification?
For the exhaust? No, just took quite a few attempts to get it angled right to clear everything!
I meant for the compressor side of the turbo, I thought bigger turbo's usually hit the bulkhead if on a t2 mani?
[Image: 20120704_212316.jpg]
#32
I didnt have any clearance issues either on the steering column or the bulkhead, I chopped my bulkhead anyway because tbh i'm irresponsible like that lol
#33
Lol i had to cut my bulkhead for my standard turbo. Need to get myself a spare manifold and see if the GT2359V will even consider fitting at the back of the bay.
Ill put up some pictures of my toy soon.
#34
[/quote]
[/quote]
Yeah had to hit it with a hammer slightly, you can see in the pic, I have painted it though so the modification blends in better. Good thing about this turbo is that the wastegate further down than a td04 so there's loads of room for an actuator.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
#35
As promised;
this was only a rough mock up during the build
[Image: IMAG0857.jpg]
[Image: 100_2148.jpg]
Just need to get this bad boy fitted;
[Image: IMAG0922_zpsf02d4869.jpg]
Stage 2 XUD Sedan
  GT2052V & TD04 Oil Feed Thread silverzx 7 5,830 18-07-2014, 05:02 PM
Last Post: Tom
