...er so...are the N/A bosch diesel XUD injectors the same as the turbo ones??.
bosch diesel injectors...
21-12-2012, 10:45 PM
Different break pressures iirc mate
21-12-2012, 10:59 PM
Bosch NA ones are tiny compared to TD's. Size does matter.
Stage 2 XUD Sedan
21-12-2012, 11:27 PM
ah lovely...as I wondered...I assumed break pressures was the differing factor...didnt realise size was too
22-12-2012, 12:53 PM
Not much in it admittedly, IDI injector nozzles don't change a massive amount... And as posted, they're 155bar vs 175bar for Turbos...
22-12-2012, 02:11 PM
that break pressue is in the spring/tip isnt it...so if I was, speaking theorecticaly, to change the tips/springs for bosch 3.1s then the break pressure wouldnt matter?!
ah...but size is different?!?! Wishes for more power...
24-12-2012, 07:50 PM
The nozzle is different as is the spring/shim stack...
You cannot just place the springs out of another injector in as they're matched, they require the pressures setting correctly with shims, which you won't have.
okeydoke. as I thought. thanks for confirmation.
swapping nozzles only..
25-12-2012, 12:34 AM
Errrr....
Can't go mixing and matching nozzles, which was kinda the point of my post... Change the entire injector as a unit unless you're sending them off to get re-shimmed and calibrated... Be aware that if one nozzle is out of calibration as far as pop pressure goes, it will affect the injection timing... Basically - get Turbo 175bar injectors... Don't try and change the nozzles yourself, or you'll end up with 4 injectors of differing break pressures, screwing up the overall timing of the engine.
25-12-2012, 10:39 AM
haha...fair play...I know one guy has done it with great success so shall enquire how...
thanks Wishes for more power...
25-12-2012, 02:21 PM
(25-12-2012, 10:39 AM)Piggy1987 Wrote: haha...fair play...I know one guy has done it with great success so shall enquire how... "Great Success"... What you mean it runs? Honestly, unless you have a pop tester and a Bosch shim set, don't even bother, you'll just end up with f*cked injectors...
25-12-2012, 02:23 PM
nah thats fair comment...I have emailed him to find out...he is on this forum...blue ph1 on speedlines.
close to 170bhp and 250 torques on a nice smooth map so he must have set them up right Wishes for more power...
25-12-2012, 04:57 PM
You can quite easily get that with dodgy injectors, it's the damage it's doing to the engine and precombustion chambers I'd be concerned about...
25-12-2012, 05:51 PM
defo me too...will do me digging and see what I get
17-02-2013, 10:37 AM
How will this do damage? Other than sound horrendous if there too soon or smoke like buggery if too late?
Bosch injectors | Niki | 12 | 8,896 |
22-07-2017, 12:20 PM Last Post: Niki |
| Are KCA 17S42 Bosch injectors rated at 175bar ok for my modified XUD? | 399road | 4 | 3,730 |
11-04-2017, 03:33 PM Last Post: 399road |
| 1.9 Bosch injectors | Leeblair98 | 2 | 2,652 |
27-04-2016, 09:39 AM Last Post: pioneer DJ paddy |
