Threads: 9
Car Model/Spec: Ph1. D Turbo
so i have a few faults on the car:
Horn doesnt work
revs work when they want to
central locking is broken (which isnt a problem until i realised my boots always open)
interior lights flash when the doors open on the door setting
indicating right or left and hazards come on( asin they both flash not the actual hazard light flashes)..
i have read guides, reviews and blogs how to fix the central locking and the only thing i can take from it is a broken wire in the door which i have to take out to look (quite a big job so itl wait)
with the horn i can hear a click so is that the relay? in case could it be a faulty horn?
with the revs could it be a faulty earth? where is this? or a possible fix?
with the indicating im assuming its also the relay as they both work together just not seperately?
with the interior light could it also be a dodgy earth as my sunroof is fine no leaks.
any earth points i can check that always go wrong? possibly point me in the right direction? maybe a product i can buy and where to get it from..
any help will be hugely appreciated so i can hurry up n get my arse on the road and come to some meets
thanks for reading
Threads: 141
35
wow that's a fair few electrical faults, but Peugeot so to be expected haha.
first off, for the horn i would find it first, in the front bumper behind the wheel arch liner, cant remember which side or if its a dual horn on a 306 sorry. once you found it check the condition of the wire itself as its prone to corrosion because of where its located.
the interior lights flashing might be an earth fault, check the earth in the drivers door, looking for loose wire/rust here, there is also an earth under the fuse box in the dash.
the rev counter could be as simple as a dirty contact on the engine side, does the rev counter work up until the car is hot then drop out or is it intermittent no matter what the temperature? the sensor is right on the back of the block over the flywheel, if you take the battery out its easy to see it, a black cable with a tapered end and a nut, simply disconnect from the block, clean the contact with a rag and some wd40 and see how that does.
indicators i would check earth points for the lights themselves, cant remember off the top of my head where youl find the earth, but itl be on the wing or the slam panel somewhere, again looking for corrosion to the contact, if that's the case, make a new earth by stripping back the wire to expose fresh copper, scrape away some paint in a new place near the original earth and simply put a new screw in with the wire trapped underneath, solder over the wire and the screw head to make an even better electrical contact. since the lights are still flashing and not just staying constantly on id be more inclined to say earth fault rather than relay.
the door looms are worth a check for any broken wires as the 306 is notorious for the loom breaking in the door, causing all sorts of problems
for the central locking, if everything is working except for the boot i would investigate the boot lock itself, check that the barrel isnt seized, can you lock the boot using the key?
erm that's all i can think of for now, always worth getting a haynes manual and looking up wiring diagrams for whats meant to be where, hope this helps you out a bit, first thing to do is get looking for those earth points, checking for corrosion to connection, making new earths if necessary see if that sorts any issues out
Threads: 465
114
Car Model/Spec: Vauxhall
list of earth points in the car
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
Tbh once you start getting electrical problems on a pug you'd be better off scrapping it and getting a push bike I find!
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 9
19-12-2012, 01:25 PM
(This post was last modified: 19-12-2012, 01:27 PM by Lew_Derv_T.)
(19-12-2012, 01:42 AM)ozonehostile Wrote: wow that's a fair few electrical faults, but Peugeot so to be expected haha.
erm that's all i can think of for now, always worth getting a haynes manual and looking up wiring diagrams for whats meant to be where, hope this helps you out a bit, first thing to do is get looking for those earth points, checking for corrosion to connection, making new earths if necessary see if that sorts any issues out  i dont think the boot can be locked anyway on a ph1 by a key? im 90% sure the rev problem is when the engine gets hot but then again i saw the needle do a dance one time then die  . the horn is a single one, theres a connector for a dual setup.
i found while stripping the rubber thing on the drivers door there some black tape around the wires, so im guessing someone has tried to fix it, the central locking locks but then pops back up.
thanks alot for the help! much appreciated
(19-12-2012, 08:35 AM)cully Wrote: list of earth points in the car
![[Image: earthpoints.jpg]](http://img.photobucket.com/albums/v159/cully/pug306/earthpoints.jpg) thanks alot thats useful
(19-12-2012, 09:39 AM)HDIkyle Wrote: Tbh once you start getting electrical problems on a pug you'd be better off scrapping it and getting a push bike I find! no thankyou, i prefer a car with no locks, no horn, and dodgy lights than a pushbike tbh pal.
i can make due with the faults for now but i not long bought the car so scrap is no chance, prefer to break it
Threads: 87
48
yes the boot will lock with the key . . .
Threads: 252
7
Do any 306's have working bootlocks? Iv had 4 with locks but even if the key goes in it won't turn
Blaze 1.6 Dead
Threads: 252
7
[/quote]
Same here but sadly mine is all engine loom and brake light wiring problems so even when it does run its not legal Lol  o well aslong as its not too wet I don't mind biking. Nicer to ride in winter than summer that's for dam sure!
Blaze 1.6 Dead
Threads: 9
so i get insured today jump start the car and it wont even start, the red light (i think its immobolizer) has only just started flashing when it hasnt since ive owned it (nov 2012), the dipped beam lights keep flashing on aswell for no reason with a clicking noise. help appreciated kinda hoping i would be driving today :/
Threads: 465
114
alarm is active disable it first button on the steering cowl i think
Threads: 141
35
sit in the car and lock then unlock the car with the key fob, if this dont work, disconnect the positive lead off the battery and short it. the alarm should blip once then hopefully the car will start. i have this issue alot....
Threads: 9
21-12-2012, 05:35 PM
(This post was last modified: 21-12-2012, 05:56 PM by Lew_Derv_T.)
short it to what the body?
ill try it tomorrow lads bit too dark now cheers
Threads: 141
35
i short it to the alarm on off key thing, you know the one by the headlight
Threads: 9
22-12-2012, 12:40 PM
(This post was last modified: 22-12-2012, 12:41 PM by Lew_Derv_T.)
lads ive gave up, f*cked me right off, the start has started all the time since i owned it now it dont even turn over, i got 11.48 volts on the battery. does anyone know someone who can come down and have a look kinda desperate?
(21-12-2012, 05:31 PM)ozonehostile Wrote: sit in the car and lock then unlock the car with the key fob, if this dont work, disconnect the positive lead off the battery and short it. the alarm should blip once then hopefully the car will start. i have this issue alot.... ive took the fuse out :/
Threads: 9
im 90% sure its the alarm/immobolizer, when i turn the key it makes a very faint electrical noise like an alarms going off, its in tune with the dipped beam lights. i looked where the key turn off is but i cant turn the key, its facing left to right so i assume thats off. i also read on another thread that one horn is the one you press and one is the alarm however i only have one, i dont know how to short it either
Threads: 141
35
have you tried just disconnecting the battery and leaving it disconnected for 20 mins?
sounds stupid I know but youl be surprised by how many electrical faults can be fixed by something so simple
Threads: 9
i fixed it turned out to be the immobiliser, the haynes said i have 10 seconds to open the door turn the ignition on and press that button and it worked  cheers for the help everyone. now to fix the other faults
Threads: 27
Car Model/Spec: Ph1 xrdt
great earth point diagram
