Threads: 143
10
Car Model/Spec: Ph3 XUD
Trying to run the power cables for my sub but having trouble finding a hole for it to go through from the engine bay.
On the Ph2 DT I just put it through a hole where the alarm siren would normally be. This is a Ph3 and the intake for the heaters is in the way. There was a power cable already there but that went under the door seal which isn't ideal, especially as mine are 4awg, so a lot thicker.
Threads: 178
28
Car Model/Spec: HDi!
Run it under the car, along the brake lines, then through a hole in the floor...
Threads: 151
14
Car Model/Spec: 306 D-turbo
Pull the carpet back under the glovebox and there is a bung for the air con I just drill a hole through there and pull the cable through.
Team Doesn't own a 306
(28-11-2012, 01:49 PM)sean-306 Wrote: Run it under the car, along the brake lines, then through a hole in the floor...
what he said. 10m of cable armour is £5 from screwfix. its the best way!
Threads: 28
Car Model/Spec: Phase 4 Silver HDi Estate
mines gone through the air con drain like mentioned
