hdi cam belt change
can any1 give me some advice i need to do my cam belt an water pump on my hdi just wondering if it a hard job to do and do i need locking pins
pins for pump and cam pulley are 8mm bolts but you may want to make a locking pin for the flywheel...hole for it behind starter if my memory serves me correctly.
not something you want to try if this is your first attempt ar mechanics but if you follow a manual you will be fine.
You're thinking of an XUD, Piggy. Very similar on an HDi, but you don't need to lock the pump off.
  Cam belt change interval... beulah 12 6,058 20-04-2014, 02:40 PM
Last Post: Toms306
