Stuck handbrake cable
How does it come out of the caliper ? As i can't shift this
[Image: 2012-11-17133035.jpg]
Tbh im probably just being thick
Does it not just pull straight out?
It's an interference fit bud get a small spanner 6mm or so, pull the rubber back put the spanner on the end metal part, and tap it with a hammer
[Image: SDC10442-1.jpg]
All sorted wasn't trying hard enough Smile
I ended up cutting mine out with an angle grinder as the f*ckers wouldn't come out. Calipers were already f*cked anyway as both had snapped nipples.
Undo behind the handbrake in the car. Will become loose at the back.
On the 306 waiting list.
  handbrake cable 306pc 2 2,445 07-01-2015, 10:55 PM
Last Post: 306pc
  Handbrake cable W1ll 7 5,144 28-04-2013, 03:07 PM
Last Post: W1ll
  replacing rear calipers/ using existing handbrake cable Lew_Derv_T 4 4,257 13-03-2013, 12:52 AM
Last Post: Lew_Derv_T
