Rpm sensor
Rpm sensor
for a 1.9 dturb...please
Have one on my old engine, or atleast I'm sure it does I have not taken anything other than the gearbox off it. Where is it, how easy to remove?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
one M6 bolt holding it on, its down the back of the block facing the flywheel and the cabel runs up to the grey plug beside the thermostat housing
(16-11-2012, 10:45 PM)HDIkyle Wrote: Have one on my old engine, or atleast I'm sure it does I have not taken anything other than the gearbox off it. Where is it, how easy to remove?
let me know mate will meet ya and get it...need one asap thanks
Will be there then ye I know which it is. I don't have a car atm but can have it if you collect it from Castleford? Setting off home now so should be back around 11:30
Blaze 1.6 Dead
(16-11-2012, 10:51 PM)Daniel306 Wrote: one M6 bolt holding it on, its down the back of the block facing the flywheel and the cabel runs up to the grey plug beside the thermostat housing
Thanks saved me searchin to find mine
