Rpm sensor - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Misc & Wanted (https://www.306oc.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Rpm sensor (/showthread.php?tid=8002) |
Rpm sensor - Lisa306 - 15-11-2012 for a 1.9 dturb...please RE: Rpm sensor - HDIkyle - 16-11-2012 Have one on my old engine, or atleast I'm sure it does I have not taken anything other than the gearbox off it. Where is it, how easy to remove? RE: Rpm sensor - Daniel306 - 16-11-2012 one M6 bolt holding it on, its down the back of the block facing the flywheel and the cabel runs up to the grey plug beside the thermostat housing RE: Rpm sensor - Lisa306 - 17-11-2012 (16-11-2012, 10:45 PM)HDIkyle Wrote: Have one on my old engine, or atleast I'm sure it does I have not taken anything other than the gearbox off it. Where is it, how easy to remove?let me know mate will meet ya and get it...need one asap thanks RE: Rpm sensor - HDIkyle - 17-11-2012 Will be there then ye I know which it is. I don't have a car atm but can have it if you collect it from Castleford? Setting off home now so should be back around 11:30 Re: RE: Rpm sensor - Tyronnster - 17-11-2012 (16-11-2012, 10:51 PM)Daniel306 Wrote: one M6 bolt holding it on, its down the back of the block facing the flywheel and the cabel runs up to the grey plug beside the thermostat housing Thanks saved me searchin to find mine |
