hubs
hubs
I am led to believe there is no diffence in hubs apart from the size of the bottom ball joint is this true????
yep, thats the only different
tu and xu are also different iirc
[Image: sig.jpg]
(12-11-2012, 05:44 PM)Chris Wrote: tu and xu are also different iirc
I have a 1.8 on a v in desperate need of a new hub again they keep f*cking up on the ball joint
ah yeah good point chris, didnt think of that
smokey, make sure you're getting the right size joint, its possible that you've been getting the smaller size and its ovalling the hub
(12-11-2012, 05:48 PM)samass Wrote: ah yeah good point chris, didnt think of that
Thats exactley wat keeps happening I almost scrapped it this morning I'm wipeing scrappys out of nearside hubs. Am I best off getting a hub and taking it to gsf and getting one that's off the new one
yep, deffo. makes sure its the right one that way
Have you tryed changing the ball joint? Get a hub from a phase 3 then buy an 18mm new ball joint. If it does it again there is somthing els at fault.
What phase/engine 306 have you got?
(12-11-2012, 06:50 PM)puglove Wrote: Have you tryed changing the ball joint? Get a hub from a phase 3 then buy an 18mm new ball joint. If it does it again there is somthing els at fault.
phase 3 1.8 16v
more than likely the 18mm ones then, that'll be the cause
As said then change the ball joint then. If it does it again then you got an issue eles where
Hdi on a v with bottom joint should fit????
in theory. unfortunately its peugeot, so difficult to say with certainty. but, it'll be more likely to be an 18mm ball joint than 16mm.
(13-11-2012, 12:27 PM)samass Wrote: in theory. unfortunately its peugeot, so difficult to say with certainty. but, it'll be more likely to be an 18mm ball joint than 16mm.
does it matter if you have 16 one side and 18 the other
Nope, not at all. As long as the hub and ball joint match, its fine. I used to have 18 on the left and 16 on the right, made no odds
Like a glove fits perfect wonder how long this one will last
  406 HUBS thethorne 45 22,016 30-11-2016, 09:13 AM
Last Post: Janne L
  XUD hubs on Hdi ct-hdi 2 2,414 09-03-2015, 07:15 AM
Last Post: Dum-Dum
  hubs cluskie 6 3,861 14-09-2014, 03:47 PM
Last Post: 306gtiparts
